1、WifiStateMachine死锁导致Binder Thread超限触发Watchdog重启 系统信息:问题发生的系统是Android P,跑压测复现到,复现过两次,目前看起来是google原生的bug。 异常报如下trace,也就是在等binderThread创建超时 Watchdog: Reporting stuck state to activity controller MonitorActivityController: ** ERROR: PROCESS NOT RESPONDING MonitorActivityController: message: Blocked in monitor com.android.server.Watchdog$BinderThreadMonitor on foreground thread (android.fg) MonitorActivityController: # MonitorActivityController: Allowing system to die. Watchdog: *** WATCHDOG KILLING SYSTEM PROCESS: Blocked in monitor com.android.server.Watchdog$BinderThreadMonitor on foreground thread (android.fg) Watchdog: android.fg annotated stack trace: Watchdog: at android.os.Binder.blockUntilThreadAvailable(Native Method) Watchdog: at com.android.server.Watchdog$BinderThreadMonitor.monitor(Watchdog.java:234) Watchdog: at com.android.server.Watchdog$HandlerChecker.run(Watchdog.java:206) Watchdog: at android.os.Handler.handleCallback(Handler.java:873) Watchdog: at android.os.Handler.dispatchMessage(Handler.java:99) Watchdog: at android.os.Looper.loop(Looper.java:193) Watchdog: at android.os.HandlerThread.run(HandlerThread.java:65) Watchdog: at com.android.server.ServiceThread.run(ServiceThread.java:44) Watchdog: *** GOODBYE! 原作者:Donald_Zhuang
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1759 浏览 0 评论
2070 浏览 1 评论
1745 浏览 1 评论
3078 浏览 1 评论
4015 浏览 1 评论
GMT+8, 2025-1-10 17:01 , Processed in 0.636764 second(s), Total 68, Slave 49 queries .
