ST意法半导体
张莉
7年用户 1252经验值
如何使用HAL_UART_Transmit_DMA函数发送数据呢?
我想使用 DMA 发送和接收数据,但是 HAL_UART_Transmit_DMA 这个函数不发送任何数据返回 HAL_BUSY 错误。
而在中断模式下的 uart 发送和接收数据都工作正常。
如何使用 DMA 发送数据?
  • /* USER CODE BEGIN Header */
  •   * @file           : main.c
  •   * @brief          : Main program body
  •   * @attention
  •   * Copyright (c) 2021 STMicroelectronics.
  •   * All rights reserved.
  •   * This software is licensed under terms that can be found in the LICENSE file
  •   * in the root directory of this software component.
  •   * If no LICENSE file comes with this software, it is provided AS-IS.
  • /* USER CODE END Header */
  • /* Includes ------------------------------------------------------------------*/
  • #include "main.h"
  • #include "dma.h"
  • #include "i2c.h"
  • #include "tim.h"
  • #include "usart.h"
  • #include "gpio.h"
  • /* Private includes ----------------------------------------------------------*/
  • /* USER CODE BEGIN Includes */
  • /* USER CODE END Includes */
  • /* Private typedef -----------------------------------------------------------*/
  • /* USER CODE BEGIN PTD */
  • /* USER CODE END PTD */
  • /* Private define ------------------------------------------------------------*/
  • /* USER CODE BEGIN PD */
  • /* USER CODE END PD */
  • /* Private macro -------------------------------------------------------------*/
  • /* USER CODE BEGIN PM */
  • /* USER CODE END PM */
  • /* Private variables ---------------------------------------------------------*/
  • /* USER CODE BEGIN PV */
  • uint8_t tx_buffer[20] = {0};
  • extern DMA_HandleTypeDef hdma_usart1_tx;
  • /* USER CODE END PV */
  • /* Private function prototypes -----------------------------------------------*/
  • void SystemClock_Config(void);
  • /* USER CODE BEGIN PFP */
  • /* USER CODE END PFP */
  • /* Private user code ---------------------------------------------------------*/
  • /* USER CODE BEGIN 0 */
  • /* USER CODE END 0 */
  •   * @brief  The application entry point.
  •   * @retval int
  • int main(void)
  •   /* USER CODE BEGIN 1 */
  •   /* USER CODE END 1 */
  •   /* MCU Configuration--------------------------------------------------------*/
  •   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  •   HAL_Init();
  •   /* USER CODE BEGIN Init */
  •   /* USER CODE END Init */
  •   /* Configure the system clock */
  •   SystemClock_Config();
  •   /* USER CODE BEGIN SysInit */
  •   /* USER CODE END SysInit */
  •   /* Initialize all configured peripherals */
  •   MX_GPIO_Init();
  •   MX_TIM3_Init();
  •   MX_USART1_UART_Init();
  •   MX_USART2_UART_Init();
  •   MX_DMA_Init();
  •   MX_I2C2_Init();
  •   /* USER CODE BEGIN 2 */
  •   for (uint8_t n = 0; n < 20; ++n) {
  •         tx_buffer[n] = n;
  •   /* USER CODE END 2 */
  •   /* Infinite loop */
  •   /* USER CODE BEGIN WHILE */
  •   while (1)
  •     /* USER CODE END WHILE */
  •     /* USER CODE BEGIN 3 */
  •           HAL_GPIO_WritePin(DR_ENABLE_GPIO_Port,DR_ENABLE_Pin,GPIO_PIN_SET);
  •                           if (HAL_UART_Transmit_DMA(&huart1, tx_buffer, 20) == HAL_OK) {
  •                                   HAL_GPIO_WritePin(DR_ENABLE_GPIO_Port,DR_ENABLE_Pin,GPIO_PIN_RESET);
  •                                   HAL_GPIO_TogglePin(ERROR_LED_GPIO_Port, ERROR_LED_Pin);
  •                           if(HAL_GPIO_ReadPin(X0_GPIO_Port, X0_Pin) == GPIO_PIN_SET){
  •                                   HAL_GPIO_WritePin(Y0_GPIO_Port, Y0_Pin, GPIO_PIN_SET);
  •                           }else {
  •                                   HAL_GPIO_WritePin(Y0_GPIO_Port, Y0_Pin, GPIO_PIN_RESET);
  •                           if (HAL_GPIO_ReadPin(X1_GPIO_Port, X1_Pin) == GPIO_PIN_SET) {
  •                                   HAL_GPIO_WritePin(Y1_GPIO_Port, Y1_Pin,GPIO_PIN_SET);
  •                           } else {
  •                                   HAL_GPIO_WritePin(Y1_GPIO_Port, Y1_Pin,GPIO_PIN_RESET);
  •                           if (HAL_GPIO_ReadPin(X2_GPIO_Port, X2_Pin) == GPIO_PIN_SET) {
  •                                   HAL_GPIO_WritePin(Y2_GPIO_Port, Y2_Pin,GPIO_PIN_SET);
  •                           } else {
  •                                   HAL_GPIO_WritePin(Y2_GPIO_Port, Y2_Pin,GPIO_PIN_RESET);
  •                           if (HAL_GPIO_ReadPin(X3_GPIO_Port, X3_Pin) == GPIO_PIN_SET) {
  •                                   HAL_GPIO_WritePin(Y3_GPIO_Port, Y3_Pin,GPIO_PIN_SET);
  •                           } else {
  •                                   HAL_GPIO_WritePin(Y3_GPIO_Port, Y3_Pin,GPIO_PIN_RESET);
  •                           if (HAL_GPIO_ReadPin(X4_GPIO_Port, X4_Pin) == GPIO_PIN_SET) {
  •                                   HAL_GPIO_WritePin(Y4_GPIO_Port, Y4_Pin,GPIO_PIN_SET);
  •                           } else {
  •                                   HAL_GPIO_WritePin(Y4_GPIO_Port, Y4_Pin,GPIO_PIN_RESET);
  •                           if (HAL_GPIO_ReadPin(X5_GPIO_Port, X5_Pin) == GPIO_PIN_SET) {
  •                                   HAL_GPIO_WritePin(Y5_GPIO_Port, Y5_Pin,GPIO_PIN_SET);
  •                           } else {
  •                                   HAL_GPIO_WritePin(Y5_GPIO_Port, Y5_Pin,GPIO_PIN_RESET);
  •                           if (HAL_GPIO_ReadPin(X6_GPIO_Port, X6_Pin) == GPIO_PIN_SET) {
  •                                   HAL_GPIO_WritePin(Y6_GPIO_Port, Y6_Pin,GPIO_PIN_SET);
  •                           } else {
  •                                   HAL_GPIO_WritePin(Y6_GPIO_Port, Y6_Pin,GPIO_PIN_RESET);
  •                           if (HAL_GPIO_ReadPin(X7_GPIO_Port, X7_Pin) == GPIO_PIN_SET) {
  •                                   HAL_GPIO_WritePin(Y7_GPIO_Port, Y7_Pin,GPIO_PIN_SET);
  •                           } else {
  •                                   HAL_GPIO_WritePin(Y7_GPIO_Port, Y7_Pin,GPIO_PIN_RESET);
  •                           if (HAL_GPIO_ReadPin(X8_GPIO_Port, X8_Pin) == GPIO_PIN_SET) {
  •                           } else {
  •                           if (HAL_GPIO_ReadPin(X9_GPIO_Port, X9_Pin) == GPIO_PIN_SET) {
  •                           } else {
  •                           if (HAL_GPIO_ReadPin(X10_GPIO_Port, X10_Pin) == GPIO_PIN_SET) {
  •                           } else {
  •                           if (HAL_GPIO_ReadPin(X11_GPIO_Port, X11_Pin) == GPIO_PIN_SET) {
  •                           } else {
  •                           if (HAL_GPIO_ReadPin(X12_GPIO_Port, X12_Pin) == GPIO_PIN_SET) {
  •                           } else {
  •                           if (HAL_GPIO_ReadPin(X13_GPIO_Port, X13_Pin) == GPIO_PIN_SET) {
  •                           } else {
  •   /* USER CODE END 3 */
  •   * @brief System Clock Configuration
  •   * @retval None
  •   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  •   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  •   RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
  •   /** Initializes the RCC Oscillators according to the specified parameters
  •   * in the RCC_OscInitTypeDef structure.
  •   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  •   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  •   RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  •   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  •   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  •   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL12;
  •   RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
  •   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  •     Error_Handler();
  •   /** Initializes the CPU, AHB and APB buses clocks
  •   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  •                               |RCC_CLOCKTYPE_PCLK1;
  •   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  •   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  •   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  •   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
  •     Error_Handler();
  •   PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
  •   PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
  •   if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
  •     Error_Handler();
  • /* USER CODE BEGIN 4 */
  • /* USER CODE END 4 */
  •   * @brief  This function is executed in case of error occurrence.
  •   * @retval None
  • void Error_Handler(void)
  •   /* USER CODE BEGIN Error_Handler_Debug */
  •   /* User can add his own implementation to report the HAL error return state */
  •   __disable_irq();
  •   while (1)
  •   /* USER CODE END Error_Handler_Debug */
  • #ifdef  USE_FULL_ASSERT
  •   * @brief  Reports the name of the source file and the source line number
  •   *         where the assert_param error has occurred.
  •   * @param  file: pointer to the source file name
  •   * @param  line: assert_param error line source number
  •   * @retval None
  • void assert_failed(uint8_t *file, uint32_t line)
  •   /* USER CODE BEGIN 6 */
  •   /* User can add his own implementation to report the file name and line number,
  •      ex: printf("Wrong parameters value: file %s on line %drn", file, line) */
  •   /* USER CODE END 6 */
  • #endif /* USE_FULL_ASSERT */
