GD32F427VEXMC系统架构图
##扩展板硬件
扩展板硬件EXMC接口部分威廉希尔官方网站
图
2.1、开发板接口部分
2.2、LCD接口部分
驱动程序
3.1、exmc.c
#include "gd32f4xx.h"
#include "exmc_lcd.h"
void exmc_lcd_init(void)
exmc_norsram_parameter_struct lcd_init_struct;
exmc_norsram_timing_parameter_struct lcd_timing_init_struct;
rcu_periph_clock_enable(RCU_EXMC);
rcu_periph_clock_enable(RCU_GPIOD);
rcu_periph_clock_enable(RCU_GPIOE);
gpio_af_set(GPIOD, GPIO_AF_12, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_8 | GPIO_PIN_9 |
GPIO_PIN_10 | GPIO_PIN_14 | GPIO_PIN_15);
gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_8 | GPIO_PIN_9 |
gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_8 | GPIO_PIN_9 |
gpio_af_set(GPIOE, GPIO_AF_12, GPIO_PIN_7 | GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 |
GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15);
gpio_mode_set(GPIOE, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_7 | GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 |
gpio_output_options_set(GPIOE, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_7 | GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 |
gpio_af_set(GPIOE, GPIO_AF_12, GPIO_PIN_2);
gpio_mode_set(GPIOE, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_2);
gpio_output_options_set(GPIOE, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_2);
gpio_af_set(GPIOD, GPIO_AF_12, GPIO_PIN_4 | GPIO_PIN_5);
gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_4 | GPIO_PIN_5);
gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_4 | GPIO_PIN_5);
gpio_af_set(GPIOD, GPIO_AF_12, GPIO_PIN_7);
gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_7);
gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_7);
lcd_timing_init_struct.asyn_access_mode = EXMC_ACCESS_MODE_A;
lcd_timing_init_struct.syn_data_latency = EXMC_DATALAT_2_CLK;
lcd_timing_init_struct.syn_clk_division = EXMC_SYN_CLOCK_RATIO_2_CLK;
lcd_timing_init_struct.bus_latency = 0;
lcd_timing_init_struct.asyn_data_setuptime = 7;
lcd_timing_init_struct.asyn_address_holdtime = 2;
lcd_timing_init_struct.asyn_address_setuptime = 5;
lcd_init_struct.norsram_region = EXMC_BANK0_NORSRAM_REGION0;
lcd_init_struct.write_mode = EXMC_ASYN_WRITE;
lcd_init_struct.extended_mode = DISABLE;
lcd_init_struct.asyn_wait = DISABLE;
lcd_init_struct.nwait_signal = DISABLE;
lcd_init_struct.memory_write = ENABLE;
lcd_init_struct.nwait_config = EXMC_NWAIT_CONFIG_BEFORE;
lcd_init_struct.wrap_burst_mode = DISABLE;
lcd_init_struct.nwait_polarity = EXMC_NWAIT_POLARITY_LOW;
lcd_init_struct.burst_mode = DISABLE;
lcd_init_struct.databus_width = EXMC_NOR_DATABUS_WIDTH_16B;
lcd_init_struct.memory_type = EXMC_MEMORY_TYPE_SRAM;
lcd_init_struct.address_data_mux = DISABLE;
lcd_init_struct.read_write_timing = &lcd_timing_init_struct;
lcd_init_struct.write_timing = &lcd_timing_init_struct;
exmc_norsram_init(&lcd_init_struct);
exmc_norsram_enable(EXMC_BANK0_NORSRAM_REGION0);
3.2、lcd.c
#include "ili9320.h"
#include "ili9320_font.h"
#include "systick.h"
#include <stdio.h>
void lcd_register_write(uint16_t register_id,uint16_t value)
*(__IO uint16_t *) (BANK0_LCD_C)= register_id;
*(__IO uint16_t *) (BANK0_LCD_D)= value;
uint16_t lcd_register_read(uint8_t register_id)
uint16_t data;
data = *(__IO uint16_t *) (BANK0_LCD_D);
return data;
void lcd_command_write(uint16_t value)
*(__IO uint16_t *) (BANK0_LCD_D) = value;
void lcd_gram_write_prepare(void)
*(__IO uint16_t *) (BANK0_LCD_C) = 0x0022;
void lcd_gram_write(uint16_t rgb_code)
*(__IO uint16_t *) (BANK0_LCD_D) = rgb_code;
uint16_t lcd_gram_read(void)
uint16_t data;
return data;
void lcd_init(void)
uint16_t i;
uint16_t device_code;
gpio_mode_set(GPIOD, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_3|GPIO_PIN_6);
gpio_bit_set(GPIOD, GPIO_PIN_3);
gpio_bit_set(GPIOD, GPIO_PIN_6);
gpio_bit_reset(GPIOD, GPIO_PIN_6);
delay_1ms(200);
delay_1ms(200);
if(1){
lcd_register_write(0x0000,0x0001);
lcd_register_write(0x0003,0xA8A4);
lcd_register_write(0x000C,0x0000);
lcd_register_write(0x000D,0x080C);
lcd_register_write(0x000E,0x2B00);
lcd_register_write(0x001E,0x00B0);
lcd_register_write(0x0001,0x2B3F);
lcd_register_write(0x0002,0x0600);
lcd_register_write(0x0010,0x0000);
lcd_register_write(0x0011,0x6070);
lcd_register_write(0x0005,0x0000);
lcd_register_write(0x0006,0x0000);
lcd_register_write(0x0016,0xEF1C);
lcd_register_write(0x0017,0x0003);
lcd_register_write(0x0007,0x0233);
lcd_register_write(0x000B,0x0000);
lcd_register_write(0x000F,0x0000);
lcd_register_write(0x0041,0x0000);
lcd_register_write(0x0042,0x0000);
lcd_register_write(0x0048,0x0000);
lcd_register_write(0x0049,0x013F);
lcd_register_write(0x004A,0x0000);
lcd_register_write(0x004B,0x0000);
lcd_register_write(0x0044,0xEF00);
lcd_register_write(0x0045,0x0000);
lcd_register_write(0x0046,0x013F);
lcd_register_write(0x0030,0x0707);
lcd_register_write(0x0031,0x0204);
lcd_register_write(0x0032,0x0204);
lcd_register_write(0x0033,0x0502);
lcd_register_write(0x0034,0x0507);
lcd_register_write(0x0035,0x0204);
lcd_register_write(0x0036,0x0204);
lcd_register_write(0x0037,0x0502);
lcd_register_write(0x003A,0x0302);
lcd_register_write(0x003B,0x0302);
lcd_register_write(0x0023,0x0000);
lcd_register_write(0x0024,0x0000);
lcd_register_write(0x0025,0x8000);
lcd_register_write(0x004e,0);
lcd_register_write(0x004f,0);
}else{
return;
for(i=50000;i>0;i--);
void lcd_cursor_set(uint16_t x,uint16_t y)
lcd_register_write(0x004e,x);
lcd_register_write(0x004f,y);
void lcd_clear(uint16_t color)
uint32_t index=0;
lcd_cursor_set(0,0);
lcd_gram_write_prepare();
for(index=0;index<76800;index++){
*(__IO uint16_t *) (BANK0_LCD_D) = color;
void lcd_point_set(uint16_t x,uint16_t y,uint16_t point)
if ((x > 240)||(y > 320)){
return;
lcd_cursor_set(x,y);
lcd_gram_write(point);
uint16_t lcd_point_get(uint16_t x,uint16_t y)
uint16_t data;
return 0;
data = lcd_gram_read();
return data;
void lcd_windows_set(uint16_t start_x,uint16_t start_y,uint16_t end_x,uint16_t end_y)
lcd_cursor_set(start_x, start_y);
lcd_register_write(0x0050, start_x);
lcd_register_write(0x0052, start_y);
lcd_register_write(0x0051, end_x);
lcd_register_write(0x0053, end_y);
void lcd_hline_draw(uint16_t x,uint16_t start_y,uint16_t end_y,uint16_t color,uint16_t width)
uint16_t i, y;
for (i = 0; i < width; i++) {
uint16_t sx = x + i;
for (y = start_y; y < end_y; y++) {
lcd_point_set(sx, y, color);
void lcd_rectangle_draw(uint16_t start_x,uint16_t start_y,uint16_t end_x,uint16_t end_y,uint16_t point)
uint16_t x,y;
x=start_x;
y=start_y;
for(x=start_x;x<end_x;x++){
lcd_point_set(x,y,point);
for(y=start_y;y<end_y;y++){
for(x=end_x;x>start_x;x--){
for(y=end_y;y>start_y;y--){
void lcd_rectangle_fill(uint16_t start_x,uint16_t start_y,uint16_t end_x,uint16_t end_y,uint16_t color)
uint16_t x, y;
x = start_x;
y = start_y;
for (x = start_x; x < end_x; x++) {
lcd_point_set(x, y, color);
void lcd_picture_draw(uint16_t start_x,uint16_t start_y,uint16_t end_x,uint16_t end_y,uint16_t *pic)
uint32_t i, total;
uint16_t *picturepointer = pic;
uint16_t x,y;
x = start_x;
y = start_y;
total = (end_x - start_x + 1) * (end_y - start_y + 1);
for(i = 0; i < total; i ++){
lcd_point_set(x,y,*picturepointer++);
x++;
if(x > end_x){
y++;
x = start_x;
void lcd_char_display(uint16_t x,uint16_t y,uint8_t c,char_format_struct c_format)
uint16_t i = 0, j = 0;
uint8_t temp_char = 0;
uint16_t temp_char_16 = 0;
if(CHAR_FONT_8_16 == c_format.font){
for (i = 0; i < 16; i++) {
temp_char = ascii_8x16[((c - 0x20) * 16) + i];
if(CHAR_DIRECTION_HORIZONTAL == c_format.direction){
for (j = 0; j < 8; j++) {
if (((temp_char >> (7 - j)) & 0x01) == 0x01) {
lcd_point_set(x - i, y + j, c_format.char_color);
} else {
lcd_point_set(x - i, y + j, c_format.bk_color);
}else{
lcd_point_set(x + j, y + i, c_format.char_color);
} else {
lcd_point_set(x + j, y + i, c_format.bk_color);
}else if(CHAR_FONT_16_24 == c_format.font){
for (i = 0; i < 24; i++) {
temp_char_16 = ASCII_Table_16x24[((c - 0x20) * 24) + i];
for (j = 0; j < 16; j++) {
if (((temp_char_16 >> j) & 0x01) == 0x01) {
} else {
}else{
} else {
3.3、main.c
#include <stdio.h>
#include "usart.h"
#include "picture.h"
char_format_struct char_format;
uint8_t gd_website_string[]={"www.gigadevice.com"} ;
int main(void)
uint16_t i;
systick_config();
init_usart();
exmc_lcd_init();
lcd_init();
lcd_clear(WHITE);
lcd_picture_draw(40,100,40+160-1,100+87-1,(uint16_t *)(picture + BMP_HEADSIZE));
lcd_rectangle_draw(10,10,230,310,BLUE);
char_format.char_color = BLUE;
char_format.bk_color = WHITE;
char_format.direction = CHAR_DIRECTION_VERTICAL;
char_format.font = CHAR_FONT_8_16;
for (i = 0; i < sizeof(gd_website_string)-1; i++){
lcd_char_display((50+8*i), 180+20, *(gd_website_string+i),char_format);
rcu_periph_clock_enable(RCU_GPIOA);
rcu_periph_clock_enable(RCU_GPIOC);
gpio_mode_set(GPIOC, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_6);
gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
gpio_bit_reset(GPIOC, GPIO_PIN_6);
gpio_mode_set(GPIOA, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_9);
gpio_mode_set(GPIOA, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_10);
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_9);
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_10);
while(1) {
gpio_bit_set(GPIOC, GPIO_PIN_6);
gpio_bit_set(GPIOA, GPIO_PIN_9);
gpio_bit_reset(GPIOA, GPIO_PIN_10);
delay_1ms(200);
gpio_bit_reset(GPIOA, GPIO_PIN_9);
gpio_bit_set(GPIOA, GPIO_PIN_10);
delay_1ms(200);
printf("a usart transmit test example!\r\n");
屏幕显示
屏幕上显示GD的logo
原作者:兆易创新GD32 MCU 小会
