代码功能是创建客户端,静态ip,在407跑通了,但是直接复制移植到429的板子就运行报错,用的ucosii,请问可能是啥原因,lwip初始化成功,tcp客户端也初始化成功,之后就运行调试串口打印出这个 那几行代码是 |
This assertion means that the q (queue) pointer in the ARP table entry is not NULL, which should not be the case when trying to find an empty entry in the ARP table. This could be caused by a memory allocation issue or a problem with the network interface driver.
One possibility is that the memory settings are different between the two boards, leading to a memory allocation error on the STM32F429 board. Another possibility is that the network interface driver code is not properly adapted to the new board and is causing the ARP table entry to be incorrectly initialized. I suggest checking the memory settings, making sure they match between the two boards, and reviewing the code for the network interface driver to ensure it is correctly configured for the STM32F429 board. It may also be helpful to debug the code and narrow down the specific line of code causing the error. |
《DNESP32S3使用指南-IDF版_V1.6》第三十五章 摄像头实验
219 浏览 0 评论
《DNESP32S3使用指南-IDF版_V1.6》第三十章 DHT11数字温湿度传感器
574 浏览 0 评论
684 浏览 0 评论
【敏矽微ME32G070开发板免费体验】之原厂2812测试例程解析
1074 浏览 0 评论
1073 浏览 2 评论
12054 浏览 31 评论
GMT+8, 2024-12-28 04:50 , Processed in 0.524935 second(s), Total 39, Slave 33 queries .
