我用SDK 3. 0将Flexcan 配置在图形界面中的Flexcan 配置为附件SDK 3. 0, 细节作为附件。 当我初始时, 使用以下代码 :
flexcan_data_info_t dataInfo =
.msg_id_type = FLEXCAN_MSG_ID_STD,
.fd_padding = 0x00,
.data_length = 8,
.fd_enable = false,
.enable_brs = false,
.is_remote = false
FLEXCAN_DRV_ConfigRxMb(0U, 0U, dataInfo, 0x300);
INT_SYS_EnableIRQ(CAN0_ORed_00_03_MB_IRQn);
FLEXCAN_DRV_Receive(0U,0U, getdata);
FLEXCAN_DRV_Init(0U, canCom0_State, canCom0_InitConfig0);
And the test result is that the 'CAN0_ORed_00_03_MB_IRQn' interrupt can't be triggered. Would you help to check the issue, is there any incorrect code?
