硬件功能 | 描述 | 硬件功能 | 描述 |
JTAG_TCLK | JTAG Test Clock | I2S1_IN_D1 | I2S1 Serial Data Input 1 |
JTAG_TDI | JTAG Test Data In | I2S1_IN_D2 | I2S1 Serial Data Input 2 |
JTAG_TMS | JTAG Test Mode Select | I2S1_IN_D3 | I2S1 Serial Data Input 3 |
JTAG_TDO | JTAG Test Data Out | I2S1_OUT_D0 | I2S1 Serial Data Output 0 |
SPI0_D0 | SPI0 Data 0 | I2S1_OUT_D1 | I2S1 Serial Data Output 1 |
SPI0_D1 | SPI0 Data 1 | I2S1_OUT_D2 | I2S1 Serial Data Output 2 |
SPI0_D2 | SPI0 Data 2 | I2S1_OUT_D3 | I2S1 Serial Data Output 3 |
SPI0_D3 | SPI0 Data 3 | I2S2_MCLK | I2S2 Master Clock |
SPI0_D4 | SPI0 Data 4 | I2S2_SCLK | I2S2 Serial Clock(BCLK) |
SPI0_D5 | SPI0 Data 5 | I2S2_WS | I2S2 Word Select(LRCLK) |
SPI0_D6 | SPI0 Data 6 | I2S2_IN_D0 | I2S2 Serial Data Input 0 |
SPI0_D7 | SPI0 Data 7 | I2S2_IN_D1 | I2S2 Serial Data Input 1 |
SPI0_SS0 | SPI0 Chip Select 0 | I2S2_IN_D2 | I2S2 Serial Data Input 2 |
SPI0_SS1 | SPI0 Chip Select 1 | I2S2_IN_D3 | I2S2 Serial Data Input 3 |
SPI0_SS2 | SPI0 Chip Select 2 | I2S2_OUT_D0 | I2S2 Serial Data Output 0 |
SPI0_SS3 | SPI0 Chip Select 3 | I2S2_OUT_D1 | I2S2 Serial Data Output 1 |
SPI0_ARB | SPI0 Arbitration | I2S2_OUT_D2 | I2S2 Serial Data Output 2 |
SPI0_SCLK | SPI0 Serial Clock | I2S2_OUT_D3 | I2S2 Serial Data Output 3 |
UARTHS_RX | UART High speed Receiver | RESV0 | Reserved function |
UARTHS_TX | UART High speed Transmitter | RESV1 | Reserved function |
RESV6 | Reserved function | RESV2 | Reserved function |
RESV7 | Reserved function | RESV3 | Reserved function |
CLK_SPI1 | Clock SPI1 | RESV4 | Reserved function |
CLK_I2C1 | Clock I2C1 | RESV5 | Reserved function |
GPIOHS0 | GPIO High speed 0 | I2C0_SCLK | I2C0 Serial Clock |
GPIOHS1 | GPIO High speed 1 | I2C0_SDA | I2C0 Serial Data |
GPIOHS2 | GPIO High speed 2 | I2C1_SCLK | I2C1 Serial Clock |
GPIOHS3 | GPIO High speed 3 | I2C1_SDA | I2C1 Serial Data |
GPIOHS4 | GPIO High speed 4 | I2C2_SCLK | I2C2 Serial Clock |
GPIOHS5 | GPIO High speed 5 | I2C2_SDA | I2C2 Serial Data |
GPIOHS6 | GPIO High speed 6 | CMOS_XCLK | DVP System Clock |
GPIOHS7 | GPIO High speed 7 | CMOS_RST | DVP System Reset |
GPIOHS8 | GPIO High speed 8 | CMOS_PWDN | DVP Power Down Mode |
GPIOHS9 | GPIO High speed 9 | CMOS_VSYNC | DVP Vertical Sync |
GPIOHS10 | GPIO High speed 10 | CMOS_HREF | DVP Horizontal Reference output |
GPIOHS11 | GPIO High speed 11 | CMOS_PCLK | Pixel Clock |
GPIOHS12 | GPIO High speed 12 | CMOS_D0 | Data Bit 0 |
GPIOHS13 | GPIO High speed 13 | CMOS_D1 | Data Bit 1 |
GPIOHS14 | GPIO High speed 14 | CMOS_D2 | Data Bit 2 |
GPIOHS15 | GPIO High speed 15 | CMOS_D3 | Data Bit 3 |
GPIOHS16 | GPIO High speed 16 | CMOS_D4 | Data Bit 4 |
GPIOHS17 | GPIO High speed 17 | CMOS_D5 | Data Bit 5 |
GPIOHS18 | GPIO High speed 18 | CMOS_D6 | Data Bit 6 |
GPIOHS19 | GPIO High speed 19 | CMOS_D7 | Data Bit 7 |
GPIOHS20 | GPIO High speed 20 | SCCB_SCLK | SCCB Serial Clock |
GPIOHS21 | GPIO High speed 21 | SCCB_SDA | SCCB Serial Data |
GPIOHS22 | GPIO High speed 22 | UART1_CTS | UART1 Clear To Send |
GPIOHS23 | GPIO High speed 23 | UART1_DSR | UART1 Data Set Ready |
GPIOHS24 | GPIO High speed 24 | UART1_DCD | UART1 Data Carrier Detect |
GPIOHS25 | GPIO High speed 25 | UART1_RI | UART1 Ring Indicator |
GPIOHS26 | GPIO High speed 26 | UART1_SIR_IN | UART1 Serial Infrared Input |
GPIOHS27 | GPIO High speed 27 | UART1_DTR | UART1 Data Terminal Ready |
GPIOHS28 | GPIO High speed 28 | UART1_RTS | UART1 Request To Send |
GPIOHS29 | GPIO High speed 29 | UART1_OUT2 | UART1 User-designated Output 2 |
GPIOHS30 | GPIO High speed 30 | UART1_OUT1 | UART1 User-designated Output 1 |
GPIOHS31 | GPIO High speed 31 | UART1_SIR_OUT | UART1 Serial Infrared Output |
GPIO0 | GPIO pin 0 | UART1_BAUD | UART1 Transmit Clock Output |
GPIO1 | GPIO pin 1 | UART1_RE | UART1 Receiver Output Enable |
GPIO2 | GPIO pin 2 | UART1_DE | UART1 Driver Output Enable |
GPIO3 | GPIO pin 3 | UART1_RS485_EN | UART1 RS485 Enable |
GPIO4 | GPIO pin 4 | UART2_CTS | UART2 Clear To Send |
GPIO5 | GPIO pin 5 | UART2_DSR | UART2 Data Set Ready |
GPIO6 | GPIO pin 6 | UART2_DCD | UART2 Data Carrier Detect |
GPIO7 | GPIO pin 7 | UART2_RI | UART2 Ring Indicator |
UART1_RX | UART1 Receiver | UART2_SIR_IN | UART2 Serial Infrared Input |
UART1_TX | UART1 Transmitter | UART2_DTR | UART2 Data Terminal Ready |
UART2_RX | UART2 Receiver | UART2_RTS | UART2 Request To Send |
UART2_TX | UART2 Transmitter | UART2_OUT2 | UART2 User-designated Output 2 |
UART3_RX | UART3 Receiver | UART2_OUT1 | UART2 User-designated Output 1 |
UART3_TX | UART3 Transmitter | UART2_SIR_OUT | UART2 Serial Infrared Output |
SPI1_D0 | SPI1 Data 0 | UART2_BAUD | UART2 Transmit Clock Output |
SPI1_D1 | SPI1 Data 1 | UART2_RE | UART2 Receiver Output Enable |
SPI1_D2 | SPI1 Data 2 | UART2_DE | UART2 Driver Output Enable |
SPI1_D3 | SPI1 Data 3 | UART2_RS485_EN | UART2 RS485 Enable |
SPI1_D4 | SPI1 Data 4 | UART3_CTS | UART3 Clear To Send |
SPI1_D5 | SPI1 Data 5 | UART3_DSR | UART3 Data Set Ready |
SPI1_D6 | SPI1 Data 6 | UART3_DCD | UART3 Data Carrier Detect |
SPI1_D7 | SPI1 Data 7 | UART3_RI | UART3 Ring Indicator |
SPI1_SS0 | SPI1 Chip Select 0 | UART3_SIR_IN | UART3 Serial Infrared Input |
SPI1_SS1 | SPI1 Chip Select 1 | UART3_DTR | UART3 Data Terminal Ready |
SPI1_SS2 | SPI1 Chip Select 2 | UART3_RTS | UART3 Request To Send |
SPI1_SS3 | SPI1 Chip Select 3 | UART3_OUT2 | UART3 User-designated Output 2 |
SPI1_ARB | SPI1 Arbitration | UART3_OUT1 | UART3 User-designated Output 1 |
SPI1_SCLK | SPI1 Serial Clock | UART3_SIR_OUT | UART3 Serial Infrared Output |
SPI_SLAVE_D0 | SPI Slave Data 0 | UART3_BAUD | UART3 Transmit Clock Output |
SPI_SLAVE_SS | SPI Slave Select | UART3_RE | UART3 Receiver Output Enable |
SPI_SLAVE_SCLK | SPI Slave Serial Clock | UART3_DE | UART3 Driver Output Enable |
I2S0_MCLK | I2S0 Master Clock | UART3_RS485_EN | UART3 RS485 Enable |
I2S0_SCLK | I2S0 Serial Clock(BCLK) | TIMER0_TOGGLE1 | TIMER0 Toggle Output 1 |
I2S0_WS | I2S0 Word Select(LRCLK) | TIMER0_TOGGLE2 | TIMER0 Toggle Output 2 |
I2S0_IN_D0 | I2S0 Serial Data Input 0 | TIMER0_TOGGLE3 | TIMER0 Toggle Output 3 |
I2S0_IN_D1 | I2S0 Serial Data Input 1 | TIMER0_TOGGLE4 | TIMER0 Toggle Output 4 |
I2S0_IN_D2 | I2S0 Serial Data Input 2 | TIMER1_TOGGLE1 | TIMER1 Toggle Output 1 |
I2S0_IN_D3 | I2S0 Serial Data Input 3 | TIMER1_TOGGLE2 | TIMER1 Toggle Output 2 |
I2S0_OUT_D0 | I2S0 Serial Data Output 0 | TIMER1_TOGGLE3 | TIMER1 Toggle Output 3 |
I2S0_OUT_D1 | I2S0 Serial Data Output 1 | TIMER1_TOGGLE4 | TIMER1 Toggle Output 4 |
I2S0_OUT_D2 | I2S0 Serial Data Output 2 | TIMER2_TOGGLE1 | TIMER2 Toggle Output 1 |
I2S0_OUT_D3 | I2S0 Serial Data Output 3 | TIMER2_TOGGLE2 | TIMER2 Toggle Output 2 |
I2S1_MCLK | I2S1 Master Clock | TIMER2_TOGGLE3 | TIMER2 Toggle Output 3 |
I2S1_SCLK | I2S1 Serial Clock(BCLK) | TIMER2_TOGGLE4 | TIMER2 Toggle Output 4 |
I2S1_WS | I2S1 Word Select(LRCLK) | CLK_SPI2 | Clock SPI2 |
I2S1_IN_D0 | I2S1 Serial Data Input 0 | CLK_I2C2 | Clock I2C2 |
