`描述 This is a 20A Communication or Enterprise Storage ASIC Adaptive Voltage Scaling (AVS) power supply using the TPS53819A PMBus PWM controller. The design enables high power density, PCB layout flexibility and ease of test and design for AVS using the PMBus interface and the Vout Adjustment and Margining Commands. The use of the external Power Block enables flexible PCB placement and upgrade to newer power blocks if needed. 特性
tidc917.zip
(875.56 KB, 下载次数: 1
PMP10778 Assembly Drawing.pdf
(83.03 KB, 下载次数: 1
PMP10778 BOM.pdf
(105.22 KB, 下载次数: 1
PMP10778 Schematic.pdf
(207.72 KB, 下载次数: 1
PMP10778 Test Results.pdf
(588.03 KB, 下载次数: 1
6314 浏览 0 评论
自己设计的Arduino UNO R3主控板原理图+PCB源文件(可直接打样)
6287 浏览 0 评论
64582 浏览 1 评论
2894 浏览 2 评论
7182 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
94197浏览 4评论
2899浏览 2评论
5173浏览 1评论
64692浏览 1评论
7186浏览 0评论
GMT+8, 2025-1-8 05:22 , Processed in 0.908493 second(s), Total 58, Slave 42 queries .
