`描述 The DC (24 V, nominal) Power-Line Communication (PLC) reference design is intended as an evaluation module that customers can use to develop end-products for industrial applications leveraging the capability to deliver both power and communications overs the same DC power line. The reference design provides a complete design guide for the hardware and firmware design of a master (PLC) node, slave (PLC) node in an extremely small (approximately 1-inch diameter) industrial form factor. The application layer handles the addressing of the slave (PLC) nodes as well as the communication from the host processor (PC or Sitara ARM MPU from Texas Instruments). The host processor communicates only to the master (PLC) node via a USB-UART interface and then master node communicates to the rest of the slave nodes over the Power Line Communication. The easy-to-use GUI is also included that can run on the host processor and provides address management as well as slave node(s) status monitoring and control to the user. At the heart of this reference design are the AFE from TI, AFE031, to interface with power lines as well as the TMS320F28035 Piccolo™ Microcontroller that runs the PLC-Lite protocol from TI. The AFE’s monolithic integrated circuit provides high reliability in demanding power-line communications applications. The F2803x Piccolo family of microcontrollers (C2000™) provides the power of the C28x core and Control Law Accelerator (CLA) coupled with highly integrated control peripherals in low pin-count devices. Based on TI’s powerful, C2000 microcontroller architecture and the AFE031, developers can select the correct blend of processing capacity and peripherals to either add power-line communications to an existing design or implement a complete application with PLC communications. 特性
slac633.zip
(3.75 MB, 下载次数: 11
slac634.zip
(1.07 MB, 下载次数: 9
slac635.zip
(8.89 MB, 下载次数: 14
slac636.zip
(1.59 MB, 下载次数: 10
slac637.zip
(732.21 KB, 下载次数: 12
DC PLC Reference Design.pdf
(2.16 MB, 下载次数: 34
DC PLC Reference Design Test Results.pdf
(1.06 MB, 下载次数: 22
4527 浏览 0 评论
自己设计的Arduino UNO R3主控板原理图+PCB源文件(可直接打样)
4497 浏览 0 评论
62910 浏览 1 评论
2855 浏览 2 评论
7145 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
92567浏览 4评论
2857浏览 2评论
5146浏览 1评论
63041浏览 1评论
7148浏览 0评论
GMT+8, 2024-12-29 23:09 , Processed in 1.027127 second(s), Total 52, Slave 38 queries .
