你可能应该做'Thomas001'所说的......在一系列捕获中构建跟踪。
至于ScanaPLUS,它看起来很有趣,但有些限制。
虽然有协议解码器,但除了简单的边缘触发器之外没有触发器。
正如您所说,看起来它可以捕获,但前提是捕获的数据可以被压缩。
当与随机数据一起使用时,不清楚深度是多少。
我可以看到,在某些情况下,它可能非常有用。
也许您可以在分段模式下使用示波器,并将Trigger Out连接到ScanaPlus上未使用的通道,以便您可以轻松找到每个数据包的开头。
免责声明:为了获得更可靠的响应,您应该考虑致电当地的Keysight技术呼叫中心。
Keysightwilliam hill官网
在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。
以上来自于谷歌翻译
以下为原文
You should probably do what 'Thomas001' says.. Build the trace over a series of captures.
As for the ScanaPLUS, it looks very interesting, but somewhat limited. While there are protocol decoders, there are no triggers, except for simple edge triggers. It looks like it can capture, as you said, but only if the captured data can be compressed. It's unclear what the depth is when used with random data. I can see that for some situations, it can be quite useful. Maybe you can use the scope in segmented mode, and connect the Trigger Out to an unused channel on the ScanaPlus, so that you can easily find the beginning of each packet.
Al
Disclaimer: For more reliable response, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
以上来自于谷歌翻译
以下为原文
Al
