您需要执行“引导功率校准”,而不是分别执行ECal和源功率校准。
此校准方法将源功率校准与您选择的S参数校准(即ECal或Mechanical)相结合,并创建一个具有S参数误差项和所需源功率偏移的校准集,并为每个校准提供额外的响应功率校正优势
您的校准中的接收器。
以下是在引导校准会话期间启用功率校准的相关命令。
*引导功率校准* *使用标准源功率命令进行高级设置。* *使用功率传感器命令配置功率传感器。* *执行功率校准* * SENS:CORR:COLL:GUID:PSENsor * *功率传感器连接器类型
* * SENS:CORR:COLL:GUID:PSEN:CONN * * Cal cal for power cal * * SENS:CORR:COLL:GUID:PSEN:CKIT * * cal的功率等级* * SENS:CORR:COLL:GUID:PSEN
:POWer:LEVel * *执行匹配校正* * SENS:CORR:METHods:MATCh *有关更多信息,您可以参考_PNA在线帮助_并在索引中查找“引导功率校准”主题。
以上来自于谷歌翻译
以下为原文
Instead of performing the ECal and source power cal separatly, you'll need to perform a "Guided Power Calibration". this calibration method combines the source power calibration with your choice of S-Parameter calibration (i.e ECal or Mechanical) and creates a calset that has both S-Parameter error terms and the required source power offset with the added benefit of response power corrections for each of the receivers in your cal.
Here are the relevant commands for enabling the power calibration during your guided calibration session.
*Guided Power Cal*
*Use standard Source Power commands to make advanced settings.*
*Use Power Sensor commands to configure the power sensor.*
*Perform power cal*
*SENS:CORR:COLL:GUID:PSENsor*
*Power sensor connector type*
*SENS:CORR:COLL:GUID:PSEN:CONN*
*Cal Kit for power cal*
*SENS:CORR:COLL:GUID:PSEN:CKIT*
*Power Level for cal*
*SENS:CORR:COLL:GUID:PSEN:POWer:LEVel*
*Perform match-correction*
*SENS:CORR:METHods:MATCh*
for more information you can refer to the
_PNA Online Help_ and in the index look for the "guided power cal" topic.
您的校准中的接收器。
以上来自于谷歌翻译
以下为原文
*Guided Power Cal*
*Perform power cal*
