SEGGER J-Link GDB Server V7.92n Command Line Version
JLinkARM.dll V7.92n (DLL compiled Oct 31 2023 15:10:15)
Command line: -port 2331 -s -device
STM32WBA52CG -endian little -speed 4000 -if swd -vd
-----GDB Server start set
tings-----
GDBInit file:                  none
GDB Server Listening port:     2331
SWO raw output listening port: 2332
Terminal I/O port:             2333
Accept remote connection:      localhost only
Generate logfile:              off
Verify download:               on
Init regs on start:            off
Silent mode:                   off
Single run mode:               on
Target connection timeout:     0 ms
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 STM32WBA52CG
Target device parameters:      none
Target interface:              SWD
Target interface speed:        4000kHz
Target endian:                 little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V9 compiled May  7 2021 16:26:12
Hardware: V9.50
S/N: 69532295
Feature(s): JFlash, GDB, RDI, FlashBP, FlashDL
Checking target voltage...
Target voltage: 3.32 V
Listening on TCP/IP port 2331
Connecting to target...
Halting core...
Core security extensions: Not implemented
Connected to target
Waiting for GDB connection...Connected to 0000:0000:0000:0000:0000:0000:0000:0001
GDB client (conn. 944) requested target.xml from GDB Server
Reading common registers: Read register 'r0' (4 bytes) from hardware: 0x07000000
Read register 'r1' (4 bytes) from hardware: 0x00000000
Read register 'r2' (4 bytes) from hardware: 0x01000000
Read register 'r3' (4 bytes) from hardware: 0x01000000
Read register 'r4' (4 bytes) from hardware: 0xF8040020
Read register 'r5' (4 bytes) from hardware: 0x44050020
Read register 'r6' (4 bytes) from hardware: 0x0000000C
Read register 'r7' (4 bytes) from hardware: 0x74FF0120
Read register 'r8' (4 bytes) from hardware: 0xFFFFFFFF
Read register 'r9' (4 bytes) from hardware: 0xD8050040
Read register 'r10' (4 bytes) from hardware: 0xFFFFFFFF
Read register 'r11' (4 bytes) from hardware: 0xFFFFFFFF
Read register 'r12' (4 bytes) from hardware: 0x54020106
Read register 'sp' (4 bytes) from hardware: 0x74FF0120
Read register 'lr' (4 bytes) from hardware: 0xD5BE0408
Read register 'pc' (4 bytes) from hardware: 0x50CA0408
Read register 'xpsr' (4 bytes) from hardware: 0x00000001
Read 4 bytes @ address 0x0804CA50 (Data = 0x681B4B05)
Received monitor command: ReadAPEx 0x1000000 0xF8
O.K.:0xE00FE003
Read 4 bytes @ address 0xE000EE08 (Data = 0x00000000)
Received monitor command: ReadMemAP 0x1000000 0xE00FEFD0 0x8 0x0
O.K.:0x00000000,0x00000000,0x00000000,0x00000000,0x00000092,0x00000004,0x0000000A,0x00000000
Reading register 'msp' = 0x2001FF74
Reading register 'psp' = 0x00000000
Read 4 bytes @ address 0x0804BED4 (Data = 0xBD80BF00)
Reading 64 bytes @ address 0x2001FF40
Read 4 bytes @ address 0x080589C4 (Data = 0x60FB69FB)
GDB client (conn. 964) requested target.xml from GDB Server
Reading 64 bytes @ address 0x2001FFC0
Read 4 bytes @ address 0x0804BEC0 (Data = 0xBD80BF00)
Read 4 bytes @ address 0x0804BFC6 (Data = 0xB580E7FC)
Downloading 348 bytes @ address 0x08000000 - Verified OK
Downloading 16148 bytes @ address 0x0800015C - Verified OK
Downloading 16192 bytes @ address 0x08004070 - Verified OK
Downloading 16272 bytes @ address 0x08007FB0 - Verified OK
Downloading 16064 bytes @ address 0x0800BF40 - Verified OK
Downloading 16144 bytes @ address 0x0800FE00 - Verified OK
Downloading 16224 bytes @ address 0x08013D10 - Verified OK
Downloading 16208 bytes @ address 0x08017C70 - Verified OK
Downloading 16112 bytes @ address 0x0801BBC0 - Verified OK
Downloading 16144 bytes @ address 0x0801FAB0 - Verified OK
Downloading 16128 bytes @ address 0x080239C0 - Verified OK
Downloading 16096 bytes @ address 0x080278C0 - Verified OK
Downloading 16160 bytes @ address 0x0802B7A0 - Verified OK
Downloading 16176 bytes @ address 0x0802F6C0 - Verified OK
Downloading 16192 bytes @ address 0x080335F0 - Verified OK
Downloading 16224 bytes @ address 0x08037530 - Verified OK
Downloading 16208 bytes @ address 0x0803B490 - Verified OK
Downloading 16160 bytes @ address 0x0803F3E0 - Verified OK
Downloading 16176 bytes @ address 0x08043300 - Verified OK
Downloading 16176 bytes @ address 0x08047230 - Verified OK
Downloading 16048 bytes @ address 0x0804B160 - Verified OK
Downloading 16000 bytes @ address 0x0804F010 - Verified OK
Downloading 16048 bytes @ address 0x08052E90 - Verified OK
Downloading 9076 bytes @ address 0x08056D40 - Verified OK
Downloading 11780 bytes @ address 0x080590B8 - Verified OK
Downloading 8 bytes @ address 0x0805BEBC - Verified OK
Downloading 4 bytes @ address 0x0805BEC4 - Verified OK
Downloading 4 bytes @ address 0x0805BEC8 - Verified OK
Downloading 1272 bytes @ address 0x0805BECC - Verified OK
Writing register 'pc' = 0x080585F0
Read 4 bytes @ address 0x080585F0 (Data = 0x46854828)
Read 2 bytes @ address 0x080585F0 (Data = 0x4828)
Starting target CPU...
GDB closed TCP/IP connection (Socket 964)
Debugger requested to halt target...
...Target halted (PC = 0x0804C398)
Reading common registers: Read register 'r0' (4 bytes) from hardware: 0x03000000
Read register 'r1' (4 bytes) from hardware: 0x00080246
Read register 'r2' (4 bytes) from hardware: 0x0030020F
Read register 'r3' (4 bytes) from hardware: 0x03000000
Read register 'r7' (4 bytes) from hardware: 0x64FF0120
Read register 'sp' (4 bytes) from hardware: 0x64FF0120
Read register 'lr' (4 bytes) from hardware: 0xF9BF0408
Read register 'pc' (4 bytes) from hardware: 0x98C30408
Read register 'xpsr' (4 bytes) from hardware: 0x00000021
Read 4 bytes @ address 0x0804C398 (Data = 0x0000E7FE)
GDB closed TCP/IP connection (Socket 944)
Restoring target state and closing J-Link connection...
Shutting down...
因为STLINKV2连接不上换成了JLINK,可以用J-Flash连接上去,并进行擦片。但是在使用CubeIDE进行调试的时候,无法进入调试状态。
以上信息是进入调试时候的打印信息,不明白在下面这个信息后
Halting core...
为什么会跳转TCP/IP这样的连接,还有这个地方突然停止核心,一般是什么原因?
用CubeIDE,我应该是可以把程序下载进入,因为我重新上电之后,可以扫描看到BLE的广播名称,并且
手机能够进行配对。
