STM32/STM8技术william hill官网
Mr_RMS
7年用户 327经验值
擅长:可编程逻辑 嵌入式技术 处理器/DSP 接口/总线/驱动 控制/MCU
USART串口问题,怎么使用USART3啊?
程序编译没问题,如下:(愁死了,一直都不行,使用的是USART3,无输出。如果换成USART1,程序做响应的修改,而且在配置option里选中use microlib 是可以的,但是为什么要选中use microlib?而且怎么才能使用USART3)用的STM32f107VC芯片串口调试助手没任何显示:
#include"stm32f10x.h"
#include
void Delay_MS(u16 dly);
void COM_Configuration(void);
u8  tab[]="nHello! everyone,welcome to class!";
int main(void)
        u8 i;
        COM_Configuration();
        printf("n Hello, very good,t %d",0x55);
        printf("nr WWW.ARMJISHU.COM! n");
        while(1)
                for(i=0;i<33;i++)
                USART_SendData(USART3, tab);
                Delay_MS(2000);
        u16 i,j;
        for(i=0;i                 for(j=1000;j>0;j--);
void COM_Configuration()
        GPIO_InitTypeDef        GPIO_InitStructure;
        USART_InitTypeDef  U3;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB ,ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        U3.USART_BaudRate =115200;
        U3.USART_WordLength = USART_WordLength_8b;
        U3.USART_StopBits = USART_StopBits_1;
        U3.USART_Parity = USART_Parity_No;
        U3.USART_Mode = USART_Mode_Rx|USART_Mode_Tx;
        U3.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_Init(USART3, &U3);
        USART_Cmd(USART3,ENABLE);
        USART_ClearFlag(USART3, USART_FLAG_TXE);
int fputc(int ch, FILE *f)
    /* e.g. write a character to the USART */
    USART_SendData(USART3, (uint8_t) ch);
    /* Loop until the end of transmission */
    while(USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET);
    return ch;
int fgetc(FILE *fp)
        int ch = 0;
    while(USART_GetFlagStatus(USART3, USART_FLAG_RXNE) == RESET);
    ch = (int)USART3->DR & 0xFF;
    putchar(ch);
        return ch;
回帖(11)
王栋春
2017-4-12 10:08:45
引用: Mr_RMS 发表于 2017-4-12 10:57
原因找到了,是我根本没理解USART串口的连接,,每个串口硬件威廉希尔官方网站 上都是连接好的,比如232串口一接的就是USART1的相关管脚,232串口2接的是USART2的相关管脚,、配置好USART3,使用232串口一这样是不行的,而是要在硬件威廉希尔官方网站 上有个232串口接的是USART3的相关管脚。。。我根本就没搞懂串口通信硬件上的意义和方式,也没搞懂23 ...
这个要多看一下相关资料  别急慢慢来
Mr_RMS
2017-4-12 10:57:04
原因找到了,是我根本没理解USART串口的连接,,每个串口硬件威廉希尔官方网站 上都是连接好的,比如232串口一接的就是USART1的相关管脚,232串口2接的是USART2的相关管脚,、配置好USART3,使用232串口一这样是不行的,而是要在硬件威廉希尔官方网站 上有个232串口接的是USART3的相关管脚。。。我根本就没搞懂串口通信硬件上的意义和方式,也没搞懂232的实际用法和威廉希尔官方网站 ,自己学的太肤浅太粗糙了,不过刚开始学,很多都不懂
猎国倾城
2017-4-12 11:34:18
在主程序里要包含stdio文件啊
Mr_RMS
2017-4-13 11:05:13
引用: 王栋春 发表于 2017-4-12 20:31
这个要多看一下相关资料  别急慢慢来
嗯嗯,谢谢 得好好看看
冯稳
2017-4-13 11:16:28
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
lee_st
2017-4-13 12:29:36
这些问题根本不用回答,太幼稚
Mr_RMS
2017-4-15 10:21:01
引用: lee_st 发表于 2017-4-13 12:29
这些问题根本不用回答,太幼稚
您牛逼,不过您也不是一开始就这么牛逼吧?您现在觉着您自己幼稚吗?肯定不幼稚,那么您觉着您儿童时您幼稚吗?您觉着您小时候穿开裆裤的时候幼稚吗?
韩棠
2018-4-8 17:33:53
我也出在这个问题上了。不过您这个答案我没太看明白
Mr_RMS
2018-4-11 10:39:12
我当时出现的错误是硬件和程序对应的问题,我在程序上使用了USART3,在开发板硬件威廉希尔官方网站 上使用的232串口1,而硬件威廉希尔官方网站 上的232串口1的管脚连接是连接到USART1的管脚,这样USART3与串口1间是没办法通信的。要使用USART3,在硬件威廉希尔官方网站 上,就要使用一个管脚与USART3的管脚相连的232串口,而不是一个管脚连接到USART1管脚的串口。。。。这是我出现错误的原因 不是知道是不是您出现问题的原因
韩棠
2018-4-14 15:36:38
引用: Mr_RMS 发表于 2018-4-11 10:39
我当时出现的错误是硬件和程序对应的问题,我在程序上使用了USART3,在开发板硬件威廉希尔官方网站 上使用的232串口1,而硬件威廉希尔官方网站 上的232串口1的管脚连接是连接到USART1的管脚,这样USART3与串口1间是没办法通信的。要使用USART3,在硬件威廉希尔官方网站 上,就要使用一个管脚与USART3的管脚相连的232串口,而不是一个管脚连接到USART1管脚的串口。 ...
今早刚解决这个问题。我的usart3乱码的原因是因为,我的板子上带了一块max3232电平转换芯片,我买了一个u***转串口的小器件,因此实际转换了两次。另外,我还有一点搞不明白的是,为什么我不加printf()函数重定向,只用usart_senddata()与usart_receivedata()是可以使用串口助手发送接收数据的,只不过程序刚开始运行时点击发送快一些,接收会乱码,但是过一段时间会稳定。这是我现在疑惑地。不过项目进度很赶,还没有时间搞清楚这个问题。
2018-5-9 16:04:54
引用: 伟伟weiwei 发表于 2018-4-14 15:36
今早刚解决这个问题。我的usart3乱码的原因是因为,我的板子上带了一块max3232电平转换芯片,我买了一个u***转串口的小器件,因此实际转换了两次。另外,我还有一点搞不明白的是,为什么我不加printf()函数重定向,只用usart_senddata()与usart_receivedata()是可以使用串口助手发送接收数据的,只不过程序刚开始运 ...
ARM嵌入式单片机学习群 524872455
