ST意法半导体
刘晓英
7年用户 182经验值
我很好奇LSM6DS3的功耗
你好。
我很好奇LSM6DS3的功耗。
LSM6DS3可以独立设置ODR。
但是,单独设置ODR时的功耗未在应用笔记中列出。
仅<仅加速度计>,<仅陀螺仪>和< Combo [Acc + Gyro]>如表6所示。我想知道如何计算它。
如果加速度计的ODR设置为208Hz且陀螺仪的ODR设置为
25Hz,传感器消耗多少功率?
#output-data-rate#lsm6ds3 #power-consumption
以上来自于谷歌翻译
以下为原文
Hello.
I am curious about the power consumption of the LSM6DS3.
The LSM6DS3 can set ODR independently.
However, the power consumption when the ODR is set independently is not listed in the Application note.
Only , and are shown in Table 6.I wonder how I can calculate it.
If the Accelerometer's ODR is set to 208Hz and the Gyroscope's ODR is set to
25Hz,how much power does the sensor consume?
#output-data-rate #lsm6ds3 #power-consumption
回帖(1)
曾玲娟
2018-9-10 17:29:33
对不起,我无法为加速器和陀螺仪ODR的所有组合提供电流消耗。
但我认为你可以从上面提到的表中粗略估计它。如果你提供你的配置(Vcc,ODR,加速模式),我也可以在一些样品上测量它。
以上来自于谷歌翻译
以下为原文
I'm sorry, I'm not able to provide the current consumption for all combination of  acceleromter and gyroscope ODRs.
But I think you can roughly estimate it from the mentioned table. If you provide me your configuration (Vcc, ODRs, accel. mode) I can also measure it on some sample.
