你好,
原则上,可以检测滑动门的运动。重力加速度将与门运动垂直,因此不是问题。
我在办公室做了自动门的快速测试(滑动门上的棒加速度计记录了加速度),在这里你可以看到结果:
我还在excel中进行了分析并添加了移动平均线:
我可以想象这可以用来举例来打开门。
我不知道你的目标到底是什么,无论如何你都会测量你的门的加速度,因为每扇门都会产生不同的模式。
以上来自于谷歌翻译
以下为原文
Hello,
in principle it is possible to detect movement of sliding doors. The gravitation acceleration will be in perpendicular axis to the door movement, so it is not a problem.
I did quick test with automatic doors in our office (stick accelerometer on sliding door record the acceleration), here you can see the results:
I also did an analysis in excel and added moving average:
I can imagine that this could be used for example to make counter of door opening.
I don't know what exactly is your target, in any case you will have measure acceleration of your doors, because each door can generate different pattern.
你好,
我可以想象这可以用来举例来打开门。
以上来自于谷歌翻译
以下为原文
Hello,
