ST意法半导体
王云玲
7年用户 186经验值
LIS3DH加速度值飙升
我最近用LIS3DH加速度计进行了一些测试来测量机器的振动,我遇到了两件事。我正在使用加速度计以1.1Khz的采样率采样512点。我把它设置为正常模式,ODR = 1.3Khz,在512点我有时得到1或2个离群值与其余值非常不同,它似乎随机发生但我不确定来源(图片)附)。
我的第二个问题是关于加速度计的固有频率,因为我在数据表中找不到它。
问候。
#lis3dh-machine#lis3dh
以上来自于谷歌翻译
以下为原文
I have been doing some testings recently with the LIS3DH accelerometer to measure machine vibration, and I have come across 2 things. I am using the accelerometer to sample 512 points at a 1.1Khz sampling rate. I have it set a normal mode, with ODR =1.3Khz, out of the 512 points I sometimes get 1 or 2 outlier points with very different values from the rest, it seems to happen randomly but I am not sure of the source (picture attached).
My second question is about the accelerometer's natural frequency as i could not find it in the datasheet.
Regards.
#lis3dh-machine #lis3dh
回帖(2)
曾玲娟
2018-10-22 16:45:44
什么是传感器配置?你启用了BDU吗?
有关加速度计固有频率的信息无法在william hill官网 上分享。
以上来自于谷歌翻译
以下为原文
What is the sensor configuration? Did you enable BDU?
The information about accelerometer's natural frequency cannot be shared on the forum.
王云玲
2018-10-22 16:58:35
是BDU已启用,BLE(0),HR已禁用。
是否至少可以确认固有频率超过1Khz?
以上来自于谷歌翻译
以下为原文
Yes BDU is enabled, BLE (0), HR disabled.
Is it at least possible to confirm that the natural frequency is over 1Khz ?
