英伟达
姚志奋
7年用户 143经验值
GRID K1 Windows 10大小怎么调整
对于基于VMware Horizo​​n View的升级项目,其中有一个从Windows 7迁移到Windows 10的请求,我遇到了这样一个事实:当选择512 MB配置文件K120Q时,不再有多监视器选项可用。
或者更好地说,它可用但不起作用...当试图开始一个会话时,它只会让我使用一个监视器,另一个仍然是空白。
我知道使用Windows 10时的大小限制,因为它更像是帧缓冲,但有些用例需要多监视器,但不需要很多帧缓冲。
我使用K140Q配置文件检查,此特定部署的帧缓冲区使用率从未达到512 MB以上,因此没有问题。
有没有办法绕过这个,让我们在K120Q配置文件上使用多个显示器?
编辑:刚注意到,在错误的部分发布了这个,有人可以将它移动到正确的william hill官网 目录吗?
以上来自于谷歌翻译
以下为原文
For an upgrade project, based on VMware Horizon View, where there was a request to migratie from Windows 7 to Windows 10 I ran into the fact that when selecting the 512 MB profile K120Q, there was no longer an option for multimonitor available. Or better said, it was available but not working... When trying to start a session, it would only let me use a single monitor, the other one remained blank.
I am aware of the sizing limitations when using Windows 10 since it is more framebuffer hungry, but there are some usecases that would need multimonitor, but not a lot of framebuffer. I checked using the K140Q profile, the framebuffer usage for this particular deployment never got above 512 MB so had no problems.
Is there any way to circumvent this and let us use multiple monitors on the K120Q profile?
Edit: just noticed, posted this in the wrong section, could someone move it to the correct forum directory?
回帖(10)
张艳梅
2018-9-13 17:13:09
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
高文利
2018-9-13 17:26:37
这是受支持的配置还是仅用于测试目的?
以上来自于谷歌翻译
以下为原文
Is this a supported configuration or is this just for testing purposes only?
李林松
2018-9-13 17:42:44
本文档的第4页说两台显示器都应该使用K120Q配置文件:
http://images.nvidia.com/content/grid/pdf/GRID-vGPU-User-Guide.pdf
所以不应该修改驱动程序。
此外,在生产环境中既不支持也不建议修改驱动程序。
以上来自于谷歌翻译
以下为原文
Page 4 of this document says that both monitors should work with the K120Q profile:
So there should be no need to modify the driver. Also, modifying the driver is neither supported or recommended in a production environment.
孙婷婷
2018-9-13 18:00:06
嗨本,
不幸的是,这对Windows 10无效。有一个单独的Messagebox表明我们不支持512MB和Windows 10的双显示器:
*剪断*
帧缓冲区小于1 GB的GRID vGPU仅支持1个虚拟显示头
在Windows 10客户操作系统上。
*剪断*
问候
西蒙
以上来自于谷歌翻译
以下为原文
Hi Ben,
unfortunately this is not valid for Windows 10. There is a seperate Messagebox indicating that we don't support Dual Monitor for 512MB and Windows 10:
*snip*
GRID vGPUs with less than 1 Gbyte of frame buffer support only 1 virtual display head
on a Windows 10 guest OS.
*snip*
Regards
Simon
