大家好,我可以使用''ST-LINK / V2''为STM8S系列编程闪存吗?
#ST-LINK / V2 以上来自于谷歌翻译 以下为原文 Hi to all,Can i use ''ST-LINK/V2'' to program flash for STM8S series? #st-link/v2 |
5个回答
我一直使用ST-LINK / V2用于STM8S部件。
以上来自于谷歌翻译 以下为原文 I use ST-LINK/V2 all the time for STM8S parts. |
大家好,我买了st-link v2,但我无法连接到stm8,在jtag上连接stm32没有问题。
stm8上的相同设备通过stm8l152C6T6_discovery_board完美连接。 我做错了什么? 以上来自于谷歌翻译 以下为原文 Hi all, I bought st-linkv2, but I can't connect to stm8, to stm32 on jtag it connect without problem. Same device on stm8 perfect connect by stm8l152C6T6_discovery_board. What do I do wrong? |
你好,
ST-LINK / V2是两个MCU系列的编程/调试工具:STM32和STM8。它们都使用不同的接口(STM32:JTAG或SWD; STM8:SWIM),因此ST-LINK / V2提供两个连接器,每个系列一个。 要将ST-LINK / V2与STM8一起使用,您需要使用名为STM8的4针连接器。这四个引脚分别为:VDD,GND,SWIM和复位。如果将这些引脚(至少VDD,GND和SWIM,因为复位是可选的)连接到相关的STM8引脚,则可以调试和编程MCU。请在下面找到显示与STM8L052连接的ST-Link / V2的照片: 如果您想将ST-LINK / V2与STM8 Discovery套件一起使用,那么首先您需要将ST-LINK / V2引脚连接到MCU引脚,然后您需要通过打开CN3上的跳线来断开Discovery工具包中嵌入的ST-LINK。请在下面找到显示以下内容的照片: Szymon 以上来自于谷歌翻译 以下为原文 Hello, ST-LINK/V2 is a programming/debugging tool for two MCUs families: STM32 and STM8. Both of them use different interface (STM32: JTAG or SWD; STM8: SWIM) and as a result ST-LINK/V2 provides two connectors, one for each family. To use ST-LINK/V2 with STM8 you need to use 4-pin connector named STM8. These four pins are: VDD, GND, SWIM and Reset. If you connect these pins (at least VDD, GND and SWIM, because Reset is optional) to relevant STM8 pins, then you are ready to debug and program the MCU. Please find below a photo showing ST-Link/V2 connected with STM8L052: If you want to use ST-LINK/V2 with STM8 Discovery kit, then first you need to connect ST-LINK/V2 pins to MCU pins and second you need to disconnect ST-LINK embedded on Discovery kit by opening jumpers on CN3. Please find below a photo showing this: Szymon |
耶士!加工。我都做对了,但我不知道一个细微差别,我的ST-LINK没有为我的设备供电。
您帮助在st-link中找到错误。 现在新问题:如何通过ST-Link V2为我的目标设备编程? 以上来自于谷歌翻译 以下为原文 Yess!! Working. I all did the right, but I did not know one nuance, my ST-LINK don't powered my device. You helped find error in st-link. And now new question: How I can powered programmed my target device via ST-LinkV2? |
你好德米特里,
我很高兴你解决了这个问题。 实际上,SWIM连接器无法为MCU供电。该连接器提供VDD引脚,但其目的不是为MCU供电,只是为了验证MCU是否已经供电。 通常,MCU应由其自己的电源供电,而不是从ST-LINK供电。但是我相信你可以使用ST-LINK来达到这个目的。基于 http://www.st.com/resource/en/user_manual/dm00026748.pdf 它看起来第二个连接器(STM32的JTAG / SWD连接器)提供3.3V和GND(引脚19和20).Regards Szymon 以上来自于谷歌翻译 以下为原文 Hello Dmitriy, I am glad that you solved the issue. Indeed SWIM connector can't supply the MCU. This connector provides a VDD pin, but its purpose is not to supply the MCU, only to verify if MCU is already supplied. Typically MCU should be supplied from its own supply source, not from ST-LINK. However I believe that you can use ST-LINK for this purpose. Based on http://www.st.com/resource/en/user_manual/dm00026748.pdf it looks that second connnector (JTAG/SWD connector for STM32) provides both 3.3V and GND (pins 19 and 20).Regards Szymon |
2785 浏览 1 评论
3252 浏览 1 评论
1827 浏览 1 评论
3672 浏览 6 评论
6068 浏览 21 评论
1350浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
374浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
470浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
294浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
218浏览 2评论
GMT+8, 2025-1-14 06:02 , Processed in 1.227043 second(s), Total 83, Slave 67 queries .
