英伟达
陈欢兆
7年用户 220经验值
启动网格K1 BSOD收到错误
你好。
我刚买了一台符合以下规格的Dell PowerEdge R720:
2个CPU E5-2650 v2
192 GB RAM,2个Perc RAID控制器(2个SATA)
1个NVidia Grid K1 vGPU卡
我按照这个程序:
- 插入Dell Open Management光盘并使用Dell内置驱动程序执行Windows 2012 Datacenter R2 x64。
-Run Dell Bios Update for R720(v2.2.3)最新版本。
-run芯片组更新和support.dell.com推荐的驱动程序(根据我的服务标签)
- 应用Windows更新并重新启动。
到目前为止系统还可以,但问题在下一步开始:
- 重启后,安装NVidia Grid vGPU驱动程序332.83(http://www.nvidia.com/download/driverResults.aspx/74598/en-us
安装此视频驱动程序后,我重新启动系统,当Windows徽标出现并等待点开始旋转时,屏幕变黑并持续几秒钟,然后我收到一个蓝屏:
Page_Fault_In_NonPaged_Area(Nvlddmkm.sys)
然后系统收集一些数据并进入无限循环的重启。
如果我以安全模式启动服务器并删除驱动程序,一切正常。
我也尝试使用驱动程序333.11 for Grid K1并收到相同的错误。
有谁知道这是一个已知的问题,还是这张卡有更新或更稳定的驱动程序?
根据NVidia支持,Windows 2012 R2支持此卡。
我还尝试了TDR注册表项值来检测延迟但没有成功!
http://www.instructables.com/id/How-to-Fix-the-Nvlddmkm-Error/
任何帮助将不胜感激!
提前致谢。
以上来自于谷歌翻译
以下为原文
Hello.
I just bought a Dell PowerEdge R720 with the following specs:
2 x CPU E5-2650 v2
192 GB RAM, 2 Perc RAID controllers (2 SATA )
1 NVidia Grid K1 vGPU Card
I followed this procedure:
-Insert Dell Open Management disc and perform Windows 2012 Datacenter R2 x64 with Dell built-in drivers.
-Run Dell Bios Update for R720 (v2.2.3) latest version.
-Run Chipset Update and recommended drivers from support.dell.com (according to my Service Tag)
-Apply Windows Updates and reboot.
The system is OK until now, but the problems begin in the next step:
-after reboot, install NVidia Grid vGPU driver 332.83 (http://www.nvidia.com/download/driverResults.aspx/74598/en-us)
after installing this video driver, I reboot the system and when Windows logo appears and waiting dots starts spinning the screen goes black for a couple of seconds and then I receive a blue screen:
Page_Fault_In_NonPaged_Area (Nvlddmkm.sys)
Then the system collects some data and enters an infinite loop of reboots.
If I start the server in Safe Mode and remove the driver everything just works fine again.
I also tried with driver 333.11 for Grid K1 and receive the same error.
Does anyone know if this is a known issue or if there is any newer or stable driver for this card?
According to NVidia support, this card is supported on Windows 2012 R2.
I also tried the TDR registry key values for detection delay but no success! (http://www.instructables.com/id/How-to-Fix-the-Nvlddmkm-Error/)
Any help will be appreciated!
Thanks in advance.
回帖(1)
杨梦月
2018-9-29 14:37:34
您确定要将驱动程序安装在4 GB内存级别以下吗?
有一个关于戴尔和NVIDIA联合推出的戴尔R720中K1 / K2的具体安装过程的综合指南,虽然我现在似乎无法通过快速搜索找到它。
以上来自于谷歌翻译
以下为原文
Were you sure to install the driver below the 4 GB memory level? There is a comprehensive guide for the specific installation process for the K1/K2 in a Dell R720 that was jointly put out by Dell and NVIDIA some time ago, though I can't seem to find it with a quick search at the moment.
