英伟达
章应苞
7年用户 214经验值
NVIDIA Grid是否支持Linux Guest VM?
您好,我目前正在运行一个应用程序,该应用程序在专用笔记本电脑上使用带有NVIDIA卡的3D图形。
我正在尝试将Linux计算机虚拟化为来宾VM,以便我可以将我的3D应用程序作为虚拟设备运行。
我已经看到NVIDIA GRID支持Windows客户机使用VMware进行图形虚拟化,但它是否也支持Linux客户机?
是否有支持此功能的VMware虚拟图形驱动程序?
谢谢!
以上来自于谷歌翻译
以下为原文
Hello, I am currently running an application that uses 3D graphics with an NVIDIA card on a dedicated laptop machine. I am trying to virtualize the Linux machine as a guest VM so that I can run my 3D application as a virtual appliance. I have seen that the NVIDIA GRID supports Windows guests machines for graphics virtualization using VMware, but does it also support Linux guests? Are there any VMware virtual graphics drivers that will support this?
Thanks!
回帖(1)
李英
2018-9-30 11:09:35
你好
是的,GRID软件支持Windows和Linux。
要获取管理程序和来宾VM的驱动程序,您需要访问:http://www.nvidia.com/object/grid-evaluation.html#utm_source=shorturl&utm_medium=referrer&utm_campaign=grid-eval and
注册评估,然后您可以开始设置过程。
只是为了让您知道,9月1日发布了一次重大升级。
GRID软件将从4.3到5.0。
如果您没有立即赶紧完成安装,那么值得等待,直到可以保存您之后立即升级。
问候
以上来自于谷歌翻译
以下为原文
Hi
Yes, the GRID software supports both Windows and Linux.
To obtain the drivers for your hypervisor and the guest VMs, you need to go here: http://www.nvidia.com/object/grid-evaluation.html#utm_source=shorturl&utm_medium=referrer&utm_campaign=grid-eval and register for an evaluation, you can then begin the setup process.
Just to let you know, there is a big upgrade being released on September 1st. The GRID software will go from 4.3 to 5.0. If you're not in an immediate rush to complete the install, it would be worth waiting until this is available to save you upgrading immediately afterwards.
Regards
Ben
