嗨,大家好,
我试图在CY8CKIT-042-BLE开发套件上使用8通道ADCXSARY-SEQ。我的第一个4通道得到合适的ADC测量读数,但无法读取电压0-995mv ADC通道4(P3 [ 4 ](P3)&;5 [ 5 ]),而不能读取电压0-311mv通道6(P3 [ 6 ](P3)&;7 [ 7 ])。我用的是台式
电源供给的输入电压直接进入adc_sar引脚通过(P3 P3 [ 0 ] - [ 7 ])。
我使用以下ADC配置:
VREF选择:外部VREF
VREF值:2.5V
单端负输入
单端结果格式:未签名
时钟源:内部
所有8个通道使用12位分辨率单端模式
ACQ时间:1.5美元
转换时间16US
你有没有什么想法可以防止4个渠道从阅读低电压?非常感谢您的宝贵时间!
以上来自于百度翻译
以下为原文
Hi All,
I'm trying to use the 8-channel ADC_SAR_SEQ on the CY8CKIT-042-BLE development kit. I can get appropriate ADC measurement readings for the first 4 channels, but the ADC cannot read voltages 0-995mV on channels 4 (P3[4]) & 5 (P3[5]), and cannot read voltages 0-311mV on channels 6 (P3[6]) & 7 (P3[7]). I am using a benchtop supply to feed the input voltage directly into the ADC_SAR pins through (P3[0]-P3[7]).
I'm using the following ADC configura
tions:
Vref Select: External Vref
Vref Value: 2.5V
Single ended negative input: Vref
Single ended result format: Unsigned
Clock source: Internal
All 8 channels use 12-bit resolution single-ended mode
Acq time: 1.5us
Conversion time 16us
Do you have any idea what could be preventing the last 4 channels from reading the low voltages? Thank you very much for your time!
