嘿所有,我们正在使用示波器:DSA-X-92504A我有一个DDR数据和一个时钟信号。
我想测量一个数据边缘(例如上升)到最近的时钟前沿(可以是上升沿或下降沿)之间的时间。 我看到的问题是所测量的数据的上升/下降沿与时钟下降沿的上升*和*有关。 每个数据边缘给我2次测量。 一个原因的衡量是错误的。 为了测量这些参数,我需要构建4个示波器设置(上升数据和上升时钟触发,下降数据和上升时钟触发等)。运行相同的数据4次。 这需要太长时间。 我需要在一个示波器设置中测量这些参数。 有谁知道如何解决这个问题? 过滤进入统计数据的结果可以通过将它们限制为UI来解决此问题(如果测量> UI =>忽略)。 但我没有找到这样的选择。 有人可以帮忙吗? 在这种情况下,eMMC合规包对我没有帮助。 请查看附件中的示例。 感谢AlexEdited:AlexBir于2015年11月30日上午6:21 以上来自于谷歌翻译 以下为原文 Hey all, We are using oscilloscope: DSA-X-92504A I have a DDR data and a clock signal. I would like to measure time between one edge of data (rising for example) to the nearest previous edge of clock (it can be rising or falling edge). The problem I see is that the same rising/falling edge of data measured related to the rising *and* to the falling edge of the clock. Each data edge gives me 2 measurements. One measurement of cause is wrong. In order to measure these parameters I need to build 4 scope setups (rising data & rising clock trigger, falling data & rising clock trigger etc.) Run the same data 4 times. It takes too long. I need to measure these parameters in one scope setup. Does anyone know how to solve this problem? Filtering results that goes into statistic can solve this issue by limit them to UI (if measurement > UI => ignore) . But I didn't find a such option. Can anyone assist please? eMMC compliance package will not help me in this case. Please take a look at the attachment for an example. Thanks Alex Edited by: AlexBir on Nov 30, 2015 6:21 AM 附件
4个回答
您没有说明您正在使用哪个范围测量,但是您是否查看了“设置”和/或“保持”测量?
另外,您是否为您的示波器运行最新版本的SW? 人 以上来自于谷歌翻译 以下为原文 You don't say which of the scope measurements you are using, but have you looked at the 'setup' and/or 'hold' measurements? Also, are you running the most recent version of SW for your scope? Al |
我们尝试使用边缘测量和增量时间测量来测量它。 建立和保持测量不是我们在这种情况下需要的测量。 从中间到中间也是衡量标准。 我们需要从时钟信号中间到数据信号SW的VOH / VOL REV:05.50.0009谢谢Alex 以上来自于谷歌翻译 以下为原文 We tried to measure it with edge-edge measurement and delta time measurement. The setup and hold measurements are not the one we need on this case. Also the are measure from middle to middle. We need from middle of clock signal to VOH/VOL of data signal SW REV: 05.50.0009 Thanks Alex |
Dang,我走开了一会儿,网站让我退出......让我看看我是否可以重新创建它。 首先,您应该更新到最新版本的SW,5.51.0002。 在这一点上,5.50.0009大约是15个修订版。 它可以在这里找到:http://www.keysight.com/main/editorial.jspx?cc = US& cs = eng& ckey = 2046387& id = 2046387我相信你需要的是设置测量。 它是从“数据”信号的当前转换到“时钟”信号的第一次转换的时间。 “时钟”和“数据”都是任意定义的。 对于您的测量t1,“数据”将是您的CLK,“时钟”将是您的数据。 至于使用的阈值,每条迹线只有一组定义的测量阈值。 但是,您可以使用“放大/复制”功能制作曲线的副本。 如果您制作2份副本,并为VOH设置一个阈值,为VOL设置一个阈值,那么您应该能够进行所需的测量。 它并不完美,但应该有效。 顺便说一句,合规性应用程序,如果它们可用于你正在使用的标准,请为你处理这个烂摊子。 在大多数情况下,他们使用函数进行测量,并过滤“不良”结果。 人 以上来自于谷歌翻译 以下为原文 Dang, I stepped away for a minute and the site logged me out... Let me see if I can recreate it. First, you should update to the latest version of SW, 5.51.0002. 5.50.0009 is about 15 revisions back, at this point. It is available here: http://www.keysight.com/main/editorial.jspx?cc=US&lc=eng&ckey=2046387&id=2046387 I believe that the setup measurement is what you need. It is the time from the current transition of a "data" signal, forward to the first transition of a "clock" signal'. Both "clock" and "data" are arbitrarily defined. For your measurement t1, "data" would be your CLK, and "clock" would be your Data. As for the thresholds used, there is only one defined set of measurement thresholds for each trace. You can, however, make copies of traces using the "magnify/duplicate" function. If you make 2 copies, and set the threshold of one for VOH and one for VOL, then you should be able to make the measurements you need. It's not perfect, but it should work. BTW, the compliance apps, if they are available for the standard you are using take care of this mess for you. In most cases, they use functions to make those measurements, and filter the 'bad' results. Al |
nvywyerwer 发表于 2018-10-1 09:09 设置时间和保持时间不是我需要的。 设置时间是从数据线到达当前逻辑电平到数据采样此级别的时间。 我需要从数据离开前一个逻辑电平到时钟中间时钟中间的时间。 保持时间相同。 =>这不是我需要的。 我需要测量eMMC协议中的tRQ和tRQH。 它不是设置和保持时间。 此外,如果我将数据作为时钟和时钟切换为数据,我将得到错误的测量 - 我想我已经厌倦了。 感谢Alex编辑:AlexBir于2015年11月30日上午8:03编辑:AlexBir于2015年11月30日下午10:20 以上来自于谷歌翻译 以下为原文 Setup time and hold time are not the the one I need. Setup time is the time from the moment data line reached the current logic level until the data sample this level. I need the time between the moment when data leave the previous logic level until the clock middle of the clock edge. The same for hold time. => it is not what I need. I need to measure tRQ and tRQH in eMMC protocol. It is not setup and hold times. Also if I switch data as clock and clock as data, I will get wrong measurements - I think I tired it already. Thanks Alex Edited by: AlexBir on Nov 30, 2015 8:03 AM Edited by: AlexBir on Nov 30, 2015 10:20 PM |
1343 浏览 0 评论
2401 浏览 1 评论
2232 浏览 1 评论
2088 浏览 5 评论
2981 浏览 3 评论
1295浏览 1评论
793浏览 0评论
1084浏览 0评论
1343浏览 0评论
GMT+8, 2025-1-28 13:44 , Processed in 1.352654 second(s), Total 51, Slave 45 queries .
