电子发烧友william hill官网
我们有自定义构建服务器与英特尔服务器主板S2600STB +两个CPU SILVER 4110 + 6模块服务器内存16GB PC19200 / REG KVR24R17S4 / 16 KINGSTON。
我们遇到的问题很奇怪。 F2后服务器启动到BIOS屏幕大约需要1分钟。 每个BIOS菜单打开需要5秒,加载默认设置和保存设置需要20秒。 此外,我们安装了Adaptec RAID kontroller。 Adaptec RAID配置也运行得非常缓慢和冻结,你可以看到每个屏幕如何绘制Debian安装,直到SSD M.2上进行20%需要2小时,Windows安装到30%需要大约4个小时。 因此,所有系统运行速度都非常慢,您可以看到每个BIOS屏幕如何在显示器上绘图,就像您拥有0.00005个CPU内核一样。 服务器是全新的,包含所有新组件。 BIOS是最新的14版本。 以上来自于谷歌翻译 以下为原文 We have custom build server with Intel Server Board S2600STB + two CPUs SILVER 4110 + 6 modules SERVER MEMORY 16GB PC19200/REG KVR24R17S4/16 KINGSTON. The problem we have is very strange. Server booting to BIOS screen after F2 takes about 1 minute. Every BIOS menu open takes 5 seconds, load default settings and save settings takes 20 seconds. Also, we have a Adaptec RAID kontroller installed. Adaptec RAID configuration also runs very slow and freezing, you can see how every screen have been drawing Debian installation till progress 20% on SSD M.2 takes 2 hours, also Windows installation till 30% takes about 4 hours. So, all system is running extremely slow, you can see how every BIOS screen have been drawing on monitor, like you have 0.00005 CPU cores. Server is brand new with all new components. BIOS are on latest 14 version. |
你好Martins B.谢谢加入社区。让我警告你,英特尔服务器主板在发布时不是最快的。
这些主板通常1分钟以上是正常的。关于BIOS菜单需要5秒20秒才能加载默认值,这绝对不正常。检查serverconfigurator.intel.com后,我发现使用的内存没有显示为已验证 。 这可能是问题的一部分。 除此之外,没有关于此RAID控制器的兼容性信息。 我可以建议尝试使用最小配置启动(没有PCI设备,1个内存模块,1个CPU),以确定性能是否有所提升。希望这会有所帮助.Jose A. 以上来自于谷歌翻译 以下为原文 Hello Martins B. Thanks for joining the community. Let me warn you that Intel server boards are not the fastest when POSTing. Usually 1+ minutes are normal for these boards. About BIOS menus taking up to 5 secs and 20 secs for loading defaults its definitely not normal. After checking the serverconfigurator.intel.com I found that the memory used doesn't show up as validated. This might be part of the issue. Besides that there is no compatibility information about this RAID controller. I could suggest to try booting up with a minimal configuration (no PCI devices, 1 mem module, 1 CPU) to find out if performance improves. Hopes this helps. Jose A. |
521浏览 0评论
GMT+8, 2024-12-27 23:16 , Processed in 0.566061 second(s), Total 76, Slave 60 queries .
