大家好,我正在尝试控制34461A万用表。
我注意到我可以通过单击显示,标签文本然后标签来手动添加文本标签。 我找到了DISP:TEXT [:DATA]“”命令,但这只会改变前面板。 我找不到更改标签的命令。 有谁知道是否有一个? 以上来自于谷歌翻译 以下为原文 Hi Everyone, I am trying to control the 34461A multimeter. I noticed that I can manually add a text label by clicking display, label text and then label on. I found the DISP:TEXT[:DATA] "" command, but that only changes the front panel. I can't find a command that changes the label. Does anyone know if there is one? |
嗨,我没有测试,但是根据手册,第403页,命令:SYSTem:LABel“”可以完成工作要检查,如果此命令与前面板条目100%等效,则可以输入标签
手动文本然后通过发送查询:SYSTem:LABel? 坦率 以上来自于谷歌翻译 以下为原文 Hi, I did not test that, but according to the manual, page 403, the command: SYSTem:LABel "" might do the job To check, if this command is 100% equivalent to the front panel entry, you might enter a label text manually and then query that by sending: SYSTem:LABel? Frank |
1330 浏览 0 评论
2396 浏览 1 评论
2215 浏览 1 评论
2084 浏览 5 评论
2972 浏览 3 评论
1226浏览 1评论
781浏览 0评论
1026浏览 0评论
1332浏览 0评论
GMT+8, 2025-1-12 17:58 , Processed in 1.166170 second(s), Total 45, Slave 39 queries .
