您好,如何找到设计使用的内存总量,设计中嵌入的位数?
我在报告中的任何地方都没有看到这一点......顺便说一下,Virtex II Pro XC2VP50的内部时钟速度是多少?而且,我怎么知道所用逻辑门的总数? 是否与LUT的数量相同,因为它基本上模拟了逻辑表达式?提前感谢Luis 以上来自于谷歌翻译 以下为原文 Hello, How can I find the total amount of memory used by the design, the number of embedded bits in the design? I don't see this anywhere in the reports... By the way, what is the internal clock speed of the Virtex II Pro XC2VP50? And also, how can I know the total number of logic gates used? Is if the same as the number of LUTs, since it basically simulates a logical expression? Thanks in advance, Luis |
PAR报告文件将包括使用的资源总数,Block RAM和分布式RAM。 >顺便问一下,Virtex II Pro XC2VP50的内部时钟速度是多少? 这取决于设计。 最大理论速度受时钟网络BUFG性能的限制,您可以通过阅读Virtex-II Pro数据表找到它。 >而且,我怎么知道使用的逻辑门总数? 这通常与您设计FPGA无关,重要的是您使用的资源量和剩余数量。 此信息可在PAR报告文件中找到。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 > How can I find the total amount of memory used by the design, the number of embedded bits in the design? The PAR report file will include the total number of resources that are used, Block RAMs and Distributed RAM. > By the way, what is the internal clock speed of the Virtex II Pro XC2VP50? This is design dependent. The maximum theoretical speed is limited by the performance of the clock network, BUFG, that you can find by reading the Virtex-II Pro data sheet. > And also, how can I know the total number of logic gates used? This is generally not relevant as you are designing an FPGA and what matters is the amount of resources that you have used and how many remain. This information can be found in the PAR report file. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
2436 浏览 7 评论
2833 浏览 4 评论
2303 浏览 9 评论
3383 浏览 0 评论
2475 浏览 15 评论
1480浏览 1评论
601浏览 1评论
467浏览 1评论
2019浏览 0评论
741浏览 0评论
GMT+8, 2025-1-2 03:27 , Processed in 1.276995 second(s), Total 78, Slave 62 queries .
