扫一扫,分享给好友
我在Windows 7上使用vivado 2014.2。
我有一个面临拥堵问题的设计,如附图中的粉红色区域所示。 在设计中,我有256位进入模块并注册。 然后通过8个阶段计算这些位的FFT。 到达第8阶段时,阵列(在模块输出上打包成单个矢量)变得太大,即2560位。 然后最后注册并进一步处理这些位。 这是我遇到拥堵的地方。 在实现过程中,设计中有大量具有重叠的节点(大约22886)。 虽然路由器设法路由设计,但我在路由过程中花费了太多时间(约6-7小时)。 有谁知道如何减少或消除这种拥堵问题? 以上来自于谷歌翻译 以下为原文 I am using vivado 2014.2 on windows 7. I have a design which is facing congestion issue as shown in pink area in figure attached. In the design, I have 256 bits entering into module and get registered. Then FFT is calculated on these bits through 8 stages. By the time i reach 8th stage , the array (which is packed into a single vector on module output) gets too big i.e 2560 bits. these bits are then finally registered and further processed. This is where i am getting congestion. During implementation design has a large number of Nodes with overlaps (around 22886). Although the router managed to route the design, I am having issue of too much time taken during routing (around 6-7 hours). Does anyone have idea how to reduce or eliminate this congestion issue? |
4个回答
嗨,
尝试拥堵策略。 您可以通过布局规划来缓解路由拥塞和时序问题,以防止逻辑在实施期间被置于关键或拥塞区域。 有关详细信息,请参阅http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug938-vivado-design-analysis-closure-tutorial.pdf的第44页。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Try congestion stratagies as well. You can alleviate routing congestion and timing issues by floorplanning to prevent logic from being placed into critical or congested areas during implementation. Refer to page 44 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug938-vivado-design-analysis-closure-tutorial.pdf for details. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution.View solution in original post |
嗨,
你尝试过不同的实施策略吗? 以上来自于谷歌翻译 以下为原文 Hi, Did you try with different implementation strategies? |
是的,我尝试FlowRuntime优化但效果不大
以上来自于谷歌翻译 以下为原文 yes i tried FlowRuntime optimized but little effect |
嗨,
尝试拥堵策略。 您可以通过布局规划来缓解路由拥塞和时序问题,以防止逻辑在实施期间被置于关键或拥塞区域。 有关详细信息,请参阅http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug938-vivado-design-analysis-closure-tutorial.pdf的第44页。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Try congestion stratagies as well. You can alleviate routing congestion and timing issues by floorplanning to prevent logic from being placed into critical or congested areas during implementation. Refer to page 44 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug938-vivado-design-analysis-closure-tutorial.pdf for details. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
2442 浏览 7 评论
2835 浏览 4 评论
2306 浏览 9 评论
3388 浏览 0 评论
2483 浏览 15 评论
1716浏览 1评论
619浏览 1评论
483浏览 1评论
2035浏览 0评论
759浏览 0评论
GMT+8, 2025-1-10 19:29 , Processed in 1.284201 second(s), Total 51, Slave 45 queries .
