你好,我正在学习如何在PIC32中使用TCP/IP协议栈。我从Microchip TCP/IP 2017类幻灯片开始,我尝试将TCP/IP堆栈从类的SydE中配置,但是我没有从发现工具或WiReSARK中得到任何东西。我尝试了所有的TCP/IP例子在./Microchip中的和声 V2Y04AppTCPIP,但是我一无所获。我正在使用。和谐V2.04和以太网启动套件I PIC32 MX795F512LI是否应该配置我的PC以太网IPv4或以某种方式得到的结果,或者在协调配置中有什么问题?你可以在附件中找到和谐的结构,谢谢。
以上来自于百度翻译 以下为原文 Hi, I am trying to learn how tcp/ip stack works in pic32. I started from Microchip TCP/IP 2017 class slides and i have tried to configure TCP/IP stack from hARMony like the sildes of the class, but i didn't get anything from discoverer tool or wireshark. I tried all the tcp/ip examples in ../microchipharmonyv2_04appstcpip, but i got nothing. I am using harmony v2.04 and Ethernet Started Kit I PIC32MX795F512L Should i configure my pc ethernet ipv4 or something in particular way to get results or there is something wrong in harmony configuration? You can find the configuration of harmony in attachments section Thanks Attached Image(s) |
6个回答
也许移动到最新的和声2.05,让其中一个例子先行。
以上来自于百度翻译 以下为原文 Maybe move to the latest Harmony 2.05 and get one of the examples going first. |
谢谢你的帮助,它现在工作,这是一个问题,我的PC以太网配置
以上来自于百度翻译 以下为原文 Thank you for your help It works now, it was a problem with my pc ethernet configuration |
你好。。我使用以太网启动套件2与MPLAB和谐。虽然我能在TCP/IP发现者中获得IP地址,但是我不能打开网页。请你帮助我。谢谢。
以上来自于百度翻译 以下为原文 Hi.. I am using ethernet starter kit 2 with mplab harmony. Though i am able to get the ip address in TCP/ip discoverer, i am not able to open the web page. Could you please help me on this. Thank you. |
启动器套件的IP地址是什么,您的PC的IP地址是什么?
以上来自于百度翻译 以下为原文 What is the IP address of the starter kit, and what is the IP address of your PC? |
谢谢你的回应。最后,我在我的电脑上更改IP后得到了IP地址
以上来自于百度翻译 以下为原文 Thank you qub for the response. Finally i got the ip address after changing ip on my pc |
5248 浏览 9 评论
2037 浏览 8 评论
1957 浏览 10 评论
3218 浏览 3 评论
2265 浏览 5 评论
788浏览 1评论
679浏览 1评论
608浏览 1评论
685浏览 0评论
582浏览 0评论
GMT+8, 2024-12-28 02:35 , Processed in 1.172447 second(s), Total 59, Slave 52 queries .
