我想测试运行ADS卡座作为示例,以显示ADS EM求解布局可用作威廉希尔官方网站
仿真中的组件。
我收到了以下错误。 似乎EM组件的引脚号是总端口号(= 10)。 但是在EM布局视图中,实际引脚数大于36(大于端口号)。 如何解决这个问题? 谢谢,(stdcmds.ael第229行,第30列)无法创建网表:在设计中“MyLibrary_lib:AC_PDN_Impedance_v1:原理图”:实例“I__8”有10个引脚,但视图“MyLibrary_lib:PDN_with_Trace_v1:emModel”需要36到37 引脚。 以上来自于谷歌翻译 以下为原文 I want to test run an ADS deck provided as an example to show a ADS EM solved layout can be used as a component in circuit simulation. I got the error below. It seems the pin number of the EM component is the total port number(=10). However in the EM layout view, the actual pin number is bigger 36(greater than port number). How to fix this? Thanks, (stdcmds.ael line 229, column 30) Failed to create netlist: In design `MyLibrary_lib:AC_PDN_Impedance_v1:schematic': The instance `I__8' has 10 pins, but the view `MyLibrary_lib:PDN_with_Trace_v1:emModel' requires 36 to 37 pins. |
它只是表示设计中的符号与引脚编号的布局不匹配。
请再次检查设计。 如果您在修复后再次看到此问题,请联系技术支持。 以上来自于谷歌翻译 以下为原文 It simply means the symbol you have in the design mismatches with the layout for the pin numbers. Please check the design again. If you see this problem again after the fix, please contact technical support. |
1296 浏览 0 评论
2378 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1136浏览 1评论
759浏览 0评论
944浏览 0评论
1296浏览 0评论
GMT+8, 2024-12-27 22:54 , Processed in 1.340322 second(s), Total 76, Slave 60 queries .
