Hitanyamohapatra93@gmail.com,
有关详细信息,请参阅此文档:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug905-vivado-hierarchical-design.pdf 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi tanyamohapatra93@gmail.com, Please refer to this document for details: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug905-vivado-hierarchical-design.pdf Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).View solution in original post |
有关详细信息,请参阅此文档:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug905-vivado-hierarchical-design.pdf 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi tanyamohapatra93@gmail.com, Please refer to this document for details: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug905-vivado-hierarchical-design.pdf Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
2446 浏览 7 评论
2845 浏览 4 评论
2308 浏览 9 评论
3390 浏览 0 评论
2485 浏览 15 评论
1749浏览 1评论
621浏览 1评论
483浏览 1评论
2036浏览 0评论
760浏览 0评论
GMT+8, 2025-1-12 04:59 , Processed in 1.222783 second(s), Total 76, Slave 60 queries .
