赛灵思
陈丽霞
7年用户 151经验值
是否可以将ISE升级到版本12.4并保留相同的许可证?
你好,
我有一个Virtex6 Ml605主板,我一直在使用12.1版的ISE设计套装。
我想知道是否可以将ISE升级到版本12.4并保留相同的许可证?
谢谢
以上来自于谷歌翻译
以下为原文
hello,
i have a Virtex6 Ml605 board, and i have been using the version 12.1 of ISE design suit. I would like to know if it is possible to upgrade the ISE to version 12.4 keeping the same license?
thanks
回帖(3)
王艳红
2018-11-26 15:17:14
是。
请在下次发布到正确的william hill官网 。
这是关于william hill官网 本身的问题;
您的问题属于安装和许可。
阿德里安
请在询问之前先查询您的问题。如果有人回答您的问题,请在“接受为解决方案”标记该帖子。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的星)。
以上来自于谷歌翻译
以下为原文
  • Yes.
  • Please post to the correct forum the next time. This one is for question concerning the forum itself; your question belongs into Installation and Licensing.
Adrian
Please google your question before asking it.
If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
李剑
2018-11-26 15:36:01
上面的“是”有一个很大的警告。
如果您的许可证版本限制为12.4,那么您可以将它用于两者。
版本限制是您不符合新更新资格的日期。
例如,假设您在2010年11月购买了ISE,版本限制为一年(大多数合同/购买都是常见的)。
这意味着您有资格获得2011年11月底之前发布的所有版本。
如果2011年12月推出新版ISE,您将_NOT_有资格在此版本的工具中使用相同的许可。
有关更多详细信息,请参阅AR 35022(http://www.xilinx.com/support/answers/35022.htm)。
-------------------------------------------这个空间故意留空
以上来自于谷歌翻译
以下为原文
There is a very big caveat to the "YES" above.  If your license version limit is such that it covers 12.4, then yes you can use it for both.
The version limit is a date after which you do not qualify for new updates.  For example, say you purchased ISE in November of 2010 and the version limit is for one year (common for most contracts/purchases).  This would mean that you would qualify for all releases released before the end of November 2011.
If a new release of ISE were to come out in December of 2011, you would _NOT_ qualify to use your same license for this release of the tools.
Please see AR 35022 (http://www.xilinx.com/support/answers/35022.htm) for more details.
this space intentionally left blank
陈光琦
2018-11-26 15:45:09
是的,它取决于许可证文件中指定的完全版本限制。
对于12.4,版本限制应为2010.11或更高版本。
如果您想了解任何特定版本,请填写此答复记录。
http://www.xilinx.com/support/answers/33770.htm
以上来自于谷歌翻译
以下为原文
Yes it depends on the version limit completely which is specified in the license file.
For 12.4 , the version limit should be 2010.11 or later. Please refr this answer record if you want to know about any particular version.
