IP版本限制遵循与Vivado版本限制相同的规则,但请注意,某些IP可能需要许可证中的特定“功能名称”才能使用。
您无法在Vivado中选择要生成的旧版IP,但是如果IP没有添加任何主要功能,它可能会保留在先前版本中使用的旧版本限制。
例如,2018.2中有一个以太网IP核,其最低版本限制为2015.04,以便使用它。
如果版本限制晚于许可证声明的版本限制,则无法使用。
-----------------------不要忘记回答,kudo,并接受为解决方案.-------------
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
IP version limits follow the same rules as the Vivado version limits, however note that certain IP's may require specific 'feature names' in the license in order to be used.
You cannot select older versions of an IP to generate in Vivado, however it is possible that if an IP hasn't had any major features added to it, it will retain an older version limit it used in a previous version.
As an example, there is an Ethernet IP core in 2018.2 has a minimum version limit of 2015.04 in order to use it.
If the version limit is later than what your license states, it cannot be used.
Don’t forget to reply, kudo, and accept as solution.
-------------------------------------------------------------------------View solution in original post
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
