你好,即使重命名和清除缓存后,如果这不起作用,那么我认为没有其他方法可以清除它。
您只能选择卸载和安装软件并再次配置许可证,但这显然是不可行的。
-Pratham ------------------------------------------------
----------------------------------------------请注意 - 请
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-
以上来自于谷歌翻译
以下为原文
Hello,
Even after renaming and clearing cache if this doesn't work then i think there are no other ways to clear it. you only have an option of uninstalling and installing software and again configuring license but that is obviously not feasible.-Pratham
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
以上来自于谷歌翻译
以下为原文
Hello,
