电子发烧友william hill官网
大家好,
我有一个有趣的困境,我无法在网上找到任何地方。 我有一个三星970 pro 512gb用于启动驱动器,WD Black 4TB Hdd用于存储,而intel optane 800p 58gb用于增强我的4tb驱动器。 我的主板是asus maximus x英雄与i7 8700k cpu。 我能够正确设置一切。 我没有将我的optane内存与我的m.2启动驱动器配对。 只是要清楚。 这不是一个大问题,但每当我从AHCI切换到RST w / optane支持时,我的三星魔术师软件就会中断并说我的970 pro不受支持。 在RST w / optane支持模式下,我仍然可以使用我的三星m.2 SSD启动。 我测试了三星ssd的速度,并没有注意到任何性能损失,但是,我不希望我的三星SSD不能正常工作因为三星m.2驱动程序和三星魔术师软件变得一团糟。 我把它还原回AHCI(使用安全模式技巧,以免它无法启动),我的M.2再次被三星魔术师软件识别,我可以看到三星m.2的健康状态和固件版本 。 所以我的问题是,是否可以在AHCI模式下使用optane内存? 我没有使用optane和我的启动驱动器,仅用于辅助驱动器。如果我想继续使用optane内存用于我的辅助驱动器,我应该只处理三星魔术师不工作? 任何想法和帮助表示赞赏! 以上来自于谷歌翻译 以下为原文 Hey guys, I've got an interesting dilemma that I haven't been able to find anywhere online. I've got a Samsung 970 pro 512gb for the boot drive, and WD Black 4TB Hdd for storage, and intel optane 800p 58gb set to boost my 4tb drive. My mobo is the asus maximus x hero with i7 8700k cpu. I'm able to setup everything properly. I am not pairing my optane memory with my m.2 boot drive. Just to be clear. It's not a huge issue, but whenever I switch from AHCI to RST w/ optane support, my samsung magician software breaks and says my 970 pro is not supported. I'm still able to boot with my samsung m.2 SSD, in RST w/ optane support mode. I tested the speed of the samsung ssd, and didn't notice any performance loss, however, I don't want my samsung SSD to not work properly simply because the samsung m.2 driver and samsung magician software becomes all screwy. I reverted it back to AHCI (using the safe mode trick so that it doesn't become unbootable) and my M.2 was recognized in samsung magician software again, and I could see the health status and firmware version of the samsung m.2. So my question is, is it possible to use optane memory in AHCI mode? I'm not using the optane with my boot drive, only for secondary drive. Should I just deal with samsung magician not working, if I want to keep using optane memory for my secondary drive? Any thoughts and help is appreciated! |
3个回答
您好Omegalazer,感谢您联系英特尔技术支持。我们了解您使用的是英特尔®Optane™SSD 800P系列58GB,M.2 80mm PCIe 3.0,3D Xpoint,可加速您的WD Black 4TB HDD二级/数据驱动器的运行
系统安装在您的Samsung 970 pro 512gb上,当您从AHCI切换到RST并支持Optane时,您就遇到了Samsung *魔术师软件的问题。 如果我们推断正确,请查看以下信息: 英特尔®Optane™SSD 800P系列58GB,M.2 80mm PCIe 3.0,3D Xpoint是SSD产品,您使用它的规格不同,因为该设备专为存储而非加速任何其他驱动器。 英特尔®Optane™内存产品专为此目的而设计,如果您遇到任何产品问题,您的保修请求可能会因您当前的配置而被拒绝。 使用英特尔®Optane™内存产品加速设备的基本要求是让您的BIOS设置与RST w / Optane支持一起使用。 此问题似乎与三星*魔术师软件完全相关,该软件似乎与您当前配置上的RST不兼容,我们建议您与三星联系以获得有关此第三方软件的进一步支持。我们希望您能找到此信息 非常有用。感谢您的耐心和理解。最重要的是,Josh B.Intel客户支持 以上来自于谷歌翻译 以下为原文 Hello Omegalazer, Thank you for contacting Intel Technical Support. As we understand you are using an Intel® Optane™ SSD 800P Series 58GB, M.2 80mm PCIe 3.0, 3D Xpoint to accelerate your WD Black 4TB HDD secondary/data drive and your operating system is set up on your Samsung 970 pro 512gb and you are having issue with the Samsung* magician software at the moment that you switch from AHCI to RST w/ Optane support. If we inferred correctly please review the information below:
We hope you find this information useful. Thank you for your patience and understanding. Best regards, Josh B. Intel Customer Support |
jerry1978 发表于 2018-12-3 15:05 为了回应上面发布的内容,这根本不是英特尔的问题。 戴尔升级到970专业版后,我遇到了同样的问题。 在不将系统更改为AHCI的情况下,魔术师无法与970交互,我无法安装专用的三星NVMe驱动程序。 以上来自于谷歌翻译 以下为原文 To echo what was posted above, this is not an Intel issue at all. I ran into the same issue with a Dell upgraded to a 970 Pro. Without changing the system to AHCI Magician could not interact with the 970 and I was unable to install the dedicated Samsung NVMe driver. |
521浏览 0评论
GMT+8, 2024-12-26 17:29 , Processed in 0.729355 second(s), Total 80, Slave 64 queries .
