英特尔
邢洋
7年用户 156经验值
没有用于Intel Optane内存的兼容磁盘
我以前使用500GB三星Evo 860 SSD作为我的启动驱动器,搭配32GB Optane模块,工作正常(所以我假设我的MB,SSD或Optane模块没有问题)。
我最近购买了500GB三星Evo 970 NVME。
我在970上重新安装了我的操作系统,并尝试将我的Optane模块与原先的860 Evo(之前使用过)配对。
我目前收到错误“没有适用于Intel Optane内存的磁盘”。
我附上了我的SSU报告
谢谢
09172018.txt.zip
8.1 K.
以上来自于谷歌翻译
以下为原文
I was previously using a 500GB Samsung Evo 860 SSD as my boot drive, paired with a 32GB Optane module, which worked fine (so i'm assuming there is no issue with my MB, SSD, or Optane module as it worked). I recently purchase a 500GB Samsung Evo 970 NVME. I reinstalled my OS on the 970, and I attempted to pair my Optane module with the original 860 Evo (which it previously worked with). I am currently getting the error "No compatible disks for Intel Optane memory". I have attached my SSU report
Thanks
回帖(9)
汤宇
2018-11-2 11:11:04
嗨bigBENmagicman,感谢您在英特尔®社区发帖。我知道您希望将您的英特尔®Optane™内存与先前配对的SATA SSD配对,对吧?我在SSU报告中看到您有3个驱动器
您的系统是2个三星驱动器和第三个1TB驱动器,对吗?根据您的描述,我了解您现在使用的是三星Evo 860 SSD作为辅助驱动器,这就是您要加速的驱动器。
如果您在对系统进行更改之前从应用程序中禁用了英特尔®Optane™内存,您能否告诉我?此外,原装三星驱动器是否仍有操作系统,或者在新驱动器中安装操作系统后将其格式化?
我会等你的回复。祝你有个美好的一天。感谢,迭戈五世。
以上来自于谷歌翻译
以下为原文
Hi bigBENmagicman,
Thank you for posting in the Intel® communities.
I understand that you want to pair your Intel® Optane™ Memory with your SATA SSD which you had previously paired, right?
I see in the SSU report that you have 3 drives in your system which are the 2 Samsung drives and a third drive of 1TB, correct?
From your description, I understand that you are using now the Samsung Evo 860 SSD as a secondary drive and that’s the one you want to accelerate. Could you please tell me if you disabled the Intel® Optane™ Memory from the application before doing the changes in the system?
Additionally, does the original Samsung drive still have the OS or you formatted it after the OS installation in the new drive?
I’ll be waiting for your response.
Have a nice day.
Regards,
Diego V.
李玉鑫
2018-11-2 11:27:57
如果您在对系统进 ...
“我知道您希望将英特尔®Optane™内存与之前配对的SATA SSD配对,对吧?”
正确
“我在SSU报告中看到你的系统中有3个驱动器,它们是2个三星驱动器,第三个驱动器是1TB,对吗?”
正确
“根据您的描述,我了解您现在正在使用三星Evo 860 SSD作为辅助驱动器,而那就是您要加速的驱动器。如果您在执行此操作之前禁用了应用程序中的英特尔®Optane™内存,请告诉我。
系统的变化?“
我没有在更改之前从应用程序中禁用Optane Memory。
我擦了我的电脑并在970上安装了Windows
谢谢
以上来自于谷歌翻译
以下为原文
"I understand that you want to pair your Intel® Optane™ Memory with your SATA SSD which you had previously paired, right?"
Correct
"I see in the SSU report that you have 3 drives in your system which are the 2 Samsung drives and a third drive of 1TB, correct?"
Correct
"From your description, I understand that you are using now the Samsung Evo 860 SSD as a secondary drive and that’s the one you want to accelerate. Could you please tell me if you disabled the Intel® Optane™ Memory from the application before doing the changes in the system?"
I did not disable the Optane Memory from the application prior to the changes. I wiped my PC and installed Windows on the 970
Thanks
汤宇
2018-11-2 11:43:54
正确
嗨bigBENmagicman,
在系统中进行任何类型的更改时,必须首先从应用程序禁用该模块。
如果尚未格式化原始驱动器,请尝试将其设置为主驱动器并尝试从中启动。
希望系统没有损坏,您将能够从仍应与英特尔®Optane™内存连接的驱动器启动。
如果有效,请转到应用程序并禁用该模块。
禁用后,再次将驱动器设置为辅助设备。
您需要格式化驱动器,因为具有2个或更多驱动器的操作系统不是受支持的配置。
有关其他信息,请查看以下文章:使用Intel®Optane™内存的辅助/数据SATA驱动器加速
此致,Diego V.
以上来自于谷歌翻译
以下为原文
Hi bigBENmagicman,
When doing any kind of change in the system, the module must be disabled first from the application.
If you haven’t formatted the original drive yet, please try to set it up as the primary drive and try booting from it. Hopefully the system wasn’t got corrupted and you will be able to boot from the drive which should still be concatenated with the Intel® Optane™ Memory. If it works, please go to application and disable the module.
Once it’s disabled, set the drive as the secondary unit again. You would need to format the drive because having 2 or more drives with OS is not a supported configuration. Please check the following article for additional information: Secondary/Data SATA Drive Acceleration with Intel® Optane™ Memory
Regards,
Diego V.
邢洋
2018-11-2 11:48:58
引用: jerry1978 发表于 2018-11-2 20:12
嗨bigBENmagicman,
不幸的是我已经格式化了另一个驱动器,我不知道我需要禁用Optane模块
以上来自于谷歌翻译
以下为原文
Unfortunately I have already formatted the other drive, I was not aware that I needed to disable the Optane module
