你好JesseB,
感谢您在英特尔®社区发帖。
我知道您在安装Intel®Optane™内存时遇到问题。
我会尽力帮助你完成这个过程。
检查附加的日志文件后,我注意到您的系统处于传统模式。
英特尔®Optane™内存无法在传统模式下运行。
它应该是UEFI模式。
您提到您在BIOS中从Legacy更改为UEFI模式,但是请您告诉我您更改了哪些设置?
如果可能的话,请截取您修改过的BIOS设置的屏幕截图,这样我就可以更好地了解您到目前为止所做的工作。
要截取屏幕截图,您需要一个USB闪存驱动器。
将其插入计算机,当您在BIOS中时,按打印屏幕按钮进行屏幕截图。
该文件将保存在USB闪存盘中。
您可以查看本指南以获取更多相关信息:http://www.unboxingtreatment.com/2018/04/howto-take-screenshot-motherboard-bios.html此外,您能否截取“磁盘管理”窗口的屏幕截图
检查驱动器中的分区?
要打开磁盘管理,请按Windows *键+ x,然后从将出现的菜单中选择“磁盘管理”选项。
进入磁盘管理后,如果右键单击每个磁盘并选择“属性”>“卷”,我们可以确认驱动器是使用MBR还是GPT分区样式。
请检查一下,并为每个驱动器截取屏幕截图,以便我也可以检查它。
我想知道的另一件事是你要加速哪个驱动器:主驱动器(启动驱动器)或辅助磁盘。
我问,因为你有MBR分区样式的辅助驱动器,但如果你想加速它,它必须使用GPT。
请检查并收集信息,以便我可以更好地帮助您。
我会等你的回复。
祝你今天愉快。
此致,Diego V.
以上来自于谷歌翻译
以下为原文
Hi JesseB,
Thank you for posting in the Intel® communities.
I understand that you are having issues installing the Intel® Optane™ Memory. I’ll try to help you with the process.
After checking the log file attached, I noticed that your system is in Legacy mode. The Intel® Optane™ Memory won’t work in Legacy mode. It should be in UEFI mode instead.
You mentioned that you changed in BIOS from Legacy to UEFI mode, however could you please tell me which settings you changed exactly? If possible please take screenshots of the BIOS settings that you modified, that way I will be able to better understand what you have done so far.
To take screenshots, you need a USB flash drive. Insert it in your computer and when you are in the BIOS, press the print screen button to take the screenshot. The file will be saved in the USB flash drive. You can check this guide for better information about this:
Additionally, could you please take a screenshot of the Disk Management window to check the partitions you have in your drives? To open Disk Management, press the
Windows* key + x and then select the Disk Management option from the menu that will appear.
Once in Disk Management, if you right click on each Disk and select
Properties>Volumes, we can confirm if the drives are using MBR or GPT partition style. Please check this too and take a screenshot for each drive so that I can check it as well.
Another thing that I’d like to know is which drive you are trying to accelerate: the primary (boot drive) or the secondary disk. I’m asking because you have the secondary drive with MBR partition style, but if you want to accelerate it, it must use GPT.
Please check this and collect the information so that I can help you in a better way.
I’ll be waiting for your response.
Have a nice day.
Regards,
Diego V.
你好JesseB,
感谢您在英特尔®社区发帖。
我会尽力帮助你完成这个过程。
它应该是UEFI模式。
该文件将保存在USB闪存盘中。
检查驱动器中的分区?
我会等你的回复。
祝你今天愉快。
此致,Diego V.
以上来自于谷歌翻译
以下为原文
Hi JesseB,
Have a nice day.
Regards,
Diego V.
