使用STM32L073RZ开发的过程中,有两个疑问请网友帮忙解答一下。谢谢!
1)在STM32L073上使用4个串口,不包括LPUART。配置USART4和5时,HAL库中定义了USART4_5_IRQn作为中断向量。是否会导致中断乱入,或者不可控。有没有网友同时使用过?如果有深入理解的朋友,能不能对原理做下解释。 /*!< Interrupt Number Definition */ typedef enum { /****** Cortex-M0 Processor Exceptions Numbers ******************************************************/ NonMaskableInt_IRQn = -14, /*!< 2 Non Maskable Interrupt */ HardFault_IRQn = -13, /*!< 3 Cortex-M0+ Hard Fault Interrupt */ SVC_IRQn = -5, /*!< 11 Cortex-M0+ SV Call Interrupt */ PendSV_IRQn = -2, /*!< 14 Cortex-M0+ Pend SV Interrupt */ SysTick_IRQn = -1, /*!< 15 Cortex-M0+ System Tick Interrupt */ /****** STM32L-0 specific Interrupt Numbers *********************************************************/ WWDG_IRQn = 0, /*!< Window WatchDog Interrupt */ PVD_IRQn = 1, /*!< PVD through EXTI Line detect Interrupt */ RTC_IRQn = 2, /*!< RTC through EXTI Line Interrupt */ FLASH_IRQn = 3, /*!< FLASH Interrupt */ RCC_CRS_IRQn = 4, /*!< RCC and CRS Interrupts */ EXTI0_1_IRQn = 5, /*!< EXTI Line 0 and 1 Interrupts */ EXTI2_3_IRQn = 6, /*!< EXTI Line 2 and 3 Interrupts */ EXTI4_15_IRQn = 7, /*!< EXTI Line 4 to 15 Interrupts */ TSC_IRQn = 8, /*!< TSC Interrupt */ DMA1_Channel1_IRQn = 9, /*!< DMA1 Channel 1 Interrupt */ DMA1_Channel2_3_IRQn = 10, /*!< DMA1 Channel 2 and Channel 3 Interrupts */ DMA1_Channel4_5_6_7_IRQn = 11, /*!< DMA1 Channel 4, Channel 5, Channel 6 and Channel 7 Interrupts */ ADC1_COMP_IRQn = 12, /*!< ADC1, COMP1 and COMP2 Interrupts */ LPTIM1_IRQn = 13, /*!< LPTIM1 Interrupt */ USART4_5_IRQn = 14, /*!< USART4 and USART5 Interrupt */ TIM2_IRQn = 15, /*!< TIM2 Interrupt */ TIM3_IRQn = 16, /*!< TIM3 Interrupt */ TIM6_DAC_IRQn = 17, /*!< TIM6 and DAC Interrupts */ TIM7_IRQn = 18, /*!< TIM7 Interrupt */ TIM21_IRQn = 20, /*!< TIM21 Interrupt */ I2C3_IRQn = 21, /*!< I2C3 Interrupt */ TIM22_IRQn = 22, /*!< TIM22 Interrupt */ I2C1_IRQn = 23, /*!< I2C1 Interrupt */ I2C2_IRQn = 24, /*!< I2C2 Interrupt */ SPI1_IRQn = 25, /*!< SPI1 Interrupt */ SPI2_IRQn = 26, /*!< SPI2 Interrupt */ USART1_IRQn = 27, /*!< USART1 Interrupt */ USART2_IRQn = 28, /*!< USART2 Interrupt */ RNG_LPUART1_IRQn = 29, /*!< RNG and LPUART1 Interrupts */ LCD_IRQn = 30, /*!< LCD Interrupt */ USB_IRQn = 31, /*!< USB global Interrupt */ } IRQn_Type; 配置USART4的代码: .... __HAL_RCC_USART4_CLK_ENABLE(); GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF6_USART4; HAL_GPIO_Init(GPIOC, &GPIO_InitStruct); /* Peripheral interrupt init */ HAL_NVIC_SetPriority(USART4_5_IRQn, 0, 0); HAL_NVIC_EnableIRQ(USART4_5_IRQn); ..... 配置USART5的代码基本也类似。中断向量号IRQn也完全一样,这样USART4和5不会冲突吗? 2)配置USART2的GPIO的Alternate 时,有: GPIO_InitStruct.Alternate = GPIO_AF0_USART2; 也有: GPIO_InitStruct.Alternate = GPIO_AF4_USART2; 这里的AF0和AF4只见存在怎样的差异,对芯片实际有什么影响? 谢谢各位不吝指点! |
6个回答
不会的,可以通过判断产生标志位来判断是哪个产生的。
参考资料上面,会有很详细的介绍!!!当然了,肯定没看!!!
本帖最后由 ataudio 于 2017-7-5 14:08 编辑 请教第二个问题,GPIO_AF0_USART2和GPIO_AF4_USART2这样的设置有什么区别呢? 现在查到了。根据参考手册,查找数据手册的ALternate function map可以找到说明。 |
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
657 浏览 0 评论
2334 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2137 浏览 3 评论
4767 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2282 浏览 1 评论
GMT+8, 2024-12-29 07:17 , Processed in 0.796811 second(s), Total 81, Slave 65 queries .
