嗨,
日志文件显示有两个SDK功能。
一个来自试用许可证,另一个来自购买的许可证,见下文。
您需要在许可证管理器中向下滚动才能查看第二个SDK功能。
根据许可优先权,购买的许可优先于试用许可,将首先选择。
有关详细信息,请访问以下网址:http://www.xilinx.com/support/answers/44024.html
谢谢,
迪皮卡。
谢谢,迪皮卡.----------------------------------------------
---------------------------------------------- Google之前的问题
张贴。
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星)
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi,
The log file shows that there are two SDK features. One is from trial license and other from purchased license see below. You need to scroll down in your license manager to view this second SDK feature.
As per the license preceedence the purchased license has more priority than trial license and it will be picked first.
Check this for more details http://www.xilinx.com/support/answers/44024.html
Thanks,
Deepika.
Thanks,
Deepika.
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post
嗨,
日志文件显示有两个SDK功能。
谢谢,
迪皮卡。
张贴。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi,
Thanks,
Deepika.
Thanks,
Deepika.
