扫一扫,分享给好友
你好,
我试图下载XAPP1052.ZIP,在下载过程中,Microsoft Security Essentials(MSE)报告说ZIP包含一个TROJAN Downloader。 下载停止,MSE弹出窗口打开,说这是一个严重的威胁,ZIP已从PC中删除。 Xilinx的任何人都可以检查ZIP文件并更正它吗? 以上来自于谷歌翻译 以下为原文 Hello, I was trying to download XAPP1052.ZIP and in the middle of the downloading, Microsoft Security Essentials (MSE) reported that the ZIP contained a TROJAN Downloader. The download stopped and a MSE popup opened saying that this was a severe threat and the ZIP was removed from the PC. Can anyone at Xilinx check the ZIP file and correct it? |
4个回答
赛义德,
我暂时允许特洛伊木马能够下载该文件。 下载后,我解压缩。 然后我删除了该木马的“允许”状态,并扫描了解压缩文件的目录。 它给了我两个文件: dma_performance_demo pcie_7x_0_example pcie_7x_0_example.runs impl_1 ISEWrap.js dma_performance_demo pcie_7x_0_example pcie_7x_0_example.runs synth_1 ISEWrap.js 由于在执行运行合成和运行实现时会重新生成这些文件,因此我只是按照MSE的建议删除了文件,并且能够生成比特流。 生成比特流后,文件再次出现,但MSE没有将其报告为被感染。 谢谢 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Syed, I have temporarily allowed the Trojan to be able to download the file. Once downloaded, I unzipped. Then I removed the "Allowed" status for the trojan and scanned the directory where the files were unzipped. It gave me two files: dma_performance_demopcie_7x_0_examplepcie_7x_0_example.runsimpl_1ISEWrap.js dma_performance_demopcie_7x_0_examplepcie_7x_0_example.runssynth_1ISEWrap.js Since these files are regenerated when doing a Run Synthesis and a Run Implementation, I just deleted the files as suggested by MSE and was able to generated the bitstream. After the bitstream was generated, the files were there again but MSE did not report them as being infected. Thanks View solution in original post |
@gymenard,
我刚刚使用以下链接下载了该文件: https://secure.xilinx.com/webreg/clickthrough.do?cid=141301&license=RefDesLicense&filename=xapp1052.zip&languageID=1 我没有看到机器上的防病毒堵塞。 我确信上面链接的zip文件不包含任何病毒文件,因此您可以在防病毒中添加此文件的例外,以便可以下载。 查看以下william hill官网 讨论: https://forums.xilinx.com/t5/Virtex-Family-FPGAs/Where-is-the-XAPP1052-pcie-performance-demo-zip-file-hiding/td-p/14554 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @gymenard, I just downloaded the file using the below link: https://secure.xilinx.com/webreg/clickthrough.do?cid=141301&license=RefDesLicense&filename=xapp1052.zip&languageID=1 I do not see an blockage from anti virus on my machine. I am sure that the zip file from above link does not contain any virus file so you can add exception to this file in you anti virus so that it can be downloaded. Check the following forum discussion: https://forums.xilinx.com/t5/Virtex-Family-FPGAs/Where-is-the-XAPP1052-pcie-performance-demo-zip-file-hiding/td-p/14554 --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
赛义德,
我暂时允许特洛伊木马能够下载该文件。 下载后,我解压缩。 然后我删除了该木马的“允许”状态,并扫描了解压缩文件的目录。 它给了我两个文件: dma_performance_demo pcie_7x_0_example pcie_7x_0_example.runs impl_1 ISEWrap.js dma_performance_demo pcie_7x_0_example pcie_7x_0_example.runs synth_1 ISEWrap.js 由于在执行运行合成和运行实现时会重新生成这些文件,因此我只是按照MSE的建议删除了文件,并且能够生成比特流。 生成比特流后,文件再次出现,但MSE没有将其报告为被感染。 谢谢 以上来自于谷歌翻译 以下为原文 Syed, I have temporarily allowed the Trojan to be able to download the file. Once downloaded, I unzipped. Then I removed the "Allowed" status for the trojan and scanned the directory where the files were unzipped. It gave me two files: dma_performance_demopcie_7x_0_examplepcie_7x_0_example.runsimpl_1ISEWrap.js dma_performance_demopcie_7x_0_examplepcie_7x_0_example.runssynth_1ISEWrap.js Since these files are regenerated when doing a Run Synthesis and a Run Implementation, I just deleted the files as suggested by MSE and was able to generated the bitstream. After the bitstream was generated, the files were there again but MSE did not report them as being infected. Thanks |
嗨gymenard,
我也有类似的问题。 我的Windows Defender反病毒隔离了我的Vivado项目中的ISEWRAP.js。 慢慢地,更多这些文件被感染并被隔离,直到Vivado / 2015.2 /脚本中的最终ISEWRAP.js被感染和隔离。 一旦该文件被隔离,如果您运行Synthesis,它将无法完成运行。 我的解决方案是从健康的PC上替换相同的文件。 合成将正常运行。 新 以上来自于谷歌翻译 以下为原文 Hi gymenard, I have a similar problem too. My Windows Defender anti virus quarantined the ISEWRAP.js in my Vivado project. Slowly, more of these files got infected and quarantined until finally ISEWRAP.js inside Vivado/2015.2/scripts got infected and quarantined. Once that file was quarantined, if you run Synthesis, it will not finish running. My solution was to replace the same file from a healthy PC. Synthesis will run properly. Neo |
2452 浏览 7 评论
2848 浏览 4 评论
2312 浏览 9 评论
3392 浏览 0 评论
2489 浏览 15 评论
1830浏览 1评论
624浏览 1评论
487浏览 1评论
2038浏览 0评论
766浏览 0评论
GMT+8, 2025-1-15 17:48 , Processed in 1.247905 second(s), Total 81, Slave 65 queries .
