#include
#define uchar unsigned char void delay(unsigned int n) //??????? {unsigned int x,y; for(x=0;x } ***it RS=P2^0; //?????***??????????? ***it RW=P2^1; ***it E=P2^2; ***it led1=P2^3; ***it led2=P2^4; int count,fen,miao,shi,k,key,i; char keyscan(); /*void write_command(char com) //д?????????? { E=0; RS=0; RW=0; P1=com; E=1; E=0; delay(1); } void write_data(char dat) //д?????????? { E=0; RS=1; RW=0; P1=dat; E=1; E=0; delay(1); } void lcd_initial(void) //lcd????? { write_command(0x38); write_command(0x0c); write_command(0x06); delay(1); } void string(uchar position,uchar *s) //?????????? { write_command(position); while(*s>0) {write_data(*s++); delay(1); } }*/ unsigned char keyscand(void) //??????躯?? { unsigned char a,b; P3=0xf0; if(P3!=0xf0) //?ж?????а??????? {delay(10); if(P3!=0xf0) //?????????? { a=P3; //???????????а????????? P3=0xf0; //????? b=P3;}} //???????????а????????? return a+b;} //?????? void main(void) { led1=1; led2=1; while(1); { P3=0xf0; key=keyscand(); switch ( key ) //?ж???????????????£? { case 0xee: k='0'; break; //??????? case 0xed: k='1'; break; case 0xeb: k='2'; break; case 0xe7: k='3'; break; case 0xde: k='4'; break; case 0xdd: k='5'; break; case 0xdb: k='6'; break; case 0xd7: k='7'; break; case 0xbe: k='8'; break; case 0xbd: k='9'; break; case 0xbb: k='A';break; case 0xb7: k='B';break; case 0x7e: k='C';break; case 0x7d: k='D';break; case 0x7b: k='E';break; case 0x77: k='F';break; } if(k=0) {led1=0;} if(k=1) led2=0;} } /* lcd_initial();//????????? EA=1; //????? ET0=1; //??????T0?????ж? TMOD=0x01; //T0???1 TH1=(65536-50000)/256;//????????????50ms TL1=(65536-50000)%256; TR0=1; IT0=1; EX0=1; EX1=1; while(1);*/ /*void timer0() interrupt 1 //?ж? { TH1=(65536-50000)/256; TL1=(65536-50000)%256; count++; //???????????????????1S string(0x81,"A331"); string(0x86,"B332"); string(0xCE,"64"); write_command(0xC1); //???shi???λ write_data(0x30+shi/10); write_command(0xC2); //???shi???λ write_data(0x30+shi%10); string(0xC3,":"); write_command(0xC4); //???fen???λ write_data(0x30+fen/10); write_command(0xC5); //???fen???λ write_data(0x30+fen%10); string(0xC6,":"); write_command(0xC7); write_data(0x30+miao/10); write_command(0xC8); write_data(0x30+miao%10); if(count==1) //20ms*50=1S {count=0; miao++;} //?????miao+1 if(miao==60) { miao=0; fen++;} //?????fen+1 if(fen==60) { fen=0; shi++;} if(shi==24) {shi=0;}}*/ |
只是说一句没反应,别人没法帮你分析的。你要把威廉希尔官方网站
图,操作过程,现象等都详细描述下,别人才好对症下药。
363 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之I2C-RTC
456 浏览 0 评论
ATK-DLRK3588开发板deepseek-r1-1.5b/7b部署指南
2206 浏览 0 评论
《DNESP32S3使用指南-IDF版_V1.6》第五十章 WiFi热点实验
675 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之I2C-温湿度传感器
814 浏览 0 评论
12343 浏览 31 评论
GMT+8, 2025-2-19 05:58 , Processed in 0.683588 second(s), Total 88, Slave 68 queries .
