扫一扫,分享给好友
嗨,我在Windows 10上安装vivado 2017.3时遇到问题。
我安装了vivado HL webPack,一切正常,直到我遇到这个问题:警告:xilinx软件安装成功,但是从以下安装后任务(生成已安装的设备列表)返回了意外状态。 单击“确定”按钮后,安装立即完成。 当我尝试运行vivado 2017.3时,我等了差不多几分钟,我得到了信息:启动时出错: Xilinx Vivado 2017.3 bin vivado.bat启动器超时。 然后,我在命令行上运行它(vivado.bat),我得到了这个: ****** Vivado v2017.3(64位)**** SW Build 2018833 on Wed Oct 4 19:58:22 MDT 2017 **** IP Build 2016188 on Wed Oct 4 21:52:56 MDT 2017 **版权所有1986-2017 Xilinx,Inc。保留所有权利。 没有错误消息。 如果有人能帮助我,我将不胜感激。 以上来自于谷歌翻译 以下为原文 hi, i encounter a problem when i install vivado 2017.3 on windows 10. i install vivado HL webPack, everything is fine until i get this problem: Warning: xilinx software was installed successfully, but an unexpected status was returned from the following post installation task(s), Generating installed device list. after i click OK button, the installation finish immediately. when i try to run vivado 2017.3, i wait almost several minutes and i got the information: error when launching: XilinxVivado2017.3binvivado.bat launcher time out. then, i run it (vivado.bat) on command line, and i get this : ****** Vivado v2017.3 (64-bit) **** SW Build 2018833 on Wed Oct 4 19:58:22 MDT 2017 **** IP Build 2016188 on Wed Oct 4 21:52:56 MDT 2017 ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved. there are no error messages. i would appreciated if anyone can help me out. |
4个回答
你好@ tiantanglu
如果您正在使用Windows 10 Creators Update,那么请检查以下答案记录: https://www.xilinx.com/support/answers/69908.html 另外,检查以下答案记录是否有帮助: https://www.xilinx.com/support/answers/69076.html 谢谢& 问候, Sravanthi B 以上来自于谷歌翻译 以下为原文 Hi @tiantanglu If you are working on Windows 10 Creators Update then please check the below Answer Record: https://www.xilinx.com/support/answers/69908.html Also, check if the below Answer Record helps: https://www.xilinx.com/support/answers/69076.html Thanks & Regards, Sravanthi B |
@tiantanglu,
检查以下答复记录: https://www.xilinx.com/support/answers/57386.html --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @tiantanglu, Check the following Answer Record: https://www.xilinx.com/support/answers/57386.html --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
亲爱的上帝,我和你有同样的问题!
(win10也是) 转到: https://www.xilinx.com/support/answers/69908.html 只需按照解决方案,它的工作! 以上来自于谷歌翻译 以下为原文 dear god, i have the same problem with you! (win10 too) goto the: https://www.xilinx.com/support/answers/69908.html just follow the solution, it work! |
你好@tiantanglu,
这应该与Win10更新有关。 试试@ pro.he提供的建议,让我们知道反馈。 问候,prathikm -------------------------------------------------- ------------如果提供的信息有用,请将相应的答案标记为“接受为解决方案”。将“Kudos”发送到您认为有用并回复的帖子.----- -------------------------------------------------- ------- 以上来自于谷歌翻译 以下为原文 Hi @tiantanglu, This should be related to the Win10 update. Just try the suggestion provided by @pro.he and let us know the feedback. Regards, prathikm -------------------------------------------------------------- Please mark the appropriate answer as "Accept as solution" if information provided is helpful. Give 'Kudos' to a post which you think is useful and reply oriented. -------------------------------------------------------------- |
2427 浏览 7 评论
2828 浏览 4 评论
2295 浏览 9 评论
3377 浏览 0 评论
2467 浏览 15 评论
1271浏览 1评论
592浏览 1评论
455浏览 1评论
2010浏览 0评论
736浏览 0评论
GMT+8, 2024-12-26 09:36 , Processed in 1.633941 second(s), Total 84, Slave 68 queries .
