电子发烧友william hill官网
您好,我对Coverage Analyst有疑问。
我使用的是Coverage Analyst版本5.21p。 覆盖率分析师完成覆盖率报告确定(html文件),但我对报告中显示的结果有疑问: - 覆盖率分析师显示某些设备(电阻器)没有与它们相关的任何测试,因此,html 每个设备的报告页面显示“测试次数= 0”。 但是: - 这些电阻中的每一个都在“模拟”文件夹中有自己的目标文件,并且它们可以通过ICT进行测试。 - 这些电阻在“board.o”文件中具有“放置”和“可测试”的属性,它们包含在“testorder”和“testplan”文件中。 所以,问题是:为什么覆盖率分析师没有证明这些电阻器已经过测试?有什么可能是错的? 在此先感谢您的帮助。 以上来自于谷歌翻译 以下为原文 Hello, I have a problem with the Coverage Analyst. I am using the Coverage Analyst version 5.21p. The Coverage Analyst finishes the coverage report ok (html files), but i have a problem with the results shown in the report: - Coverage Analyst shows that some devices (Resistors) do not have any test associated with them, so as, the html report-page of each device shows "Number of tests = 0". But: - Each one of these resistors have their own object file in the "analog" folder, and they are tested ok with the ICT. - These resistors have the properties "placed" and "testable" in the file "board.o", and they are included in the "testorder" and "testplan" files. So, the question is: Why the Coverage Analyst does not show that these resistors are tested?, What can be wrong? Thanks in advance for your help. |
6个回答
嗨jmvicent,我可以知道哪个类别是威廉希尔官方网站
板文件中找到的电阻?
它们属于RESISTOR类别还是PIN LIBRARY? 您想将测试目录发送给我们吗? 这将使我们能够确定原因。 请发送到adrian_cheong@agilent.com谢谢... adrian 以上来自于谷歌翻译 以下为原文 Hi jmvicent, May I know which category are the resistors found in the board file? Are they under the RESISTOR category or in PIN LIBRARY? Would you like to send us the test directory? This will allow us to determine the reason for this. Please send to adrian_cheong@agilent.com Thanks ... adrian |
JasonXiong 发表于 2019-1-7 18:57 嗨adrianc,电阻属于RESISTOR类别。 对不起,我不能发送测试目录。 谢谢,。 何塞 以上来自于谷歌翻译 以下为原文 Hi adrianc, the resistors are under the RESISTOR category. I am sorry, but i can't send you the test directory. Thanks,. Jose |
这是唯一表现出这种症状的测试目录吗? 以上来自于谷歌翻译 以下为原文 Is this the only test directory that is exhibiting this symptom? |
嗨,是的,这是唯一有此问题的测试目录。 谢谢,何塞 以上来自于谷歌翻译 以下为原文 Hi, Yes, this is the only test directory with this problem. Thanks, Jose |
嗨jmvicent,“覆盖率分析师显示某些设备(电阻器)没有与之相关的任何测试”>>覆盖率分析报告中是否缺少所有电阻? 还是只是一些? 对于Coverage Analyst报告中缺少的那些电阻,请选择一个示例。 - 模拟目录中的电阻测试文件,是否经过电阻测试声明评论? 例如 !电阻器909,1.32,1.17,re2,ar20.0m,ed,sa,***,sl,en你能给我发一个电阻测试源文件吗? - 测试订单文件包括电阻测试。 在测试订单中找到以下哪些陈述,例如 测试电阻“r121”; nulltest测试电阻“r120”; 注释测试电阻“r122” - 测试计划文件包括电阻测试。 测试位于哪个测试部分? 请将测试所在的测试子程序的副本发送给我,例如: sub Analog_Tests - 再次在testplan中,是在“sub Test_Sections”子程序中调用的子程序吗? 例如 调用Analog_Tests(Failed_In_Analog,Mode $& AnalogMsg $)谢谢。 以上来自于谷歌翻译 以下为原文 Hi jmvicent, "Coverage Analyst shows that some devices (Resistors) do not have any test associated with them" >> are all the resistors missing in the Coverage Analyst report? or just some? For those resistors that are missing in the Coverage Analyst report, choose one example. - the resistor test file in the analog directory, is the resistor test statement commented? e.g. !resistor 909, 1.32, 1.17, re2, ar20.0m, ed, sa, ***, sl, en Can you send me one of the resistor test source file? - the testorder file includes the resistor test. Which of the below statements is found in the testorder e.g. test resistor "r121"; nulltest test resistor "r120"; comment test resistor "r122" - the testplan file includes the resistor test. What test section is the test located in? Please send me a copy of the test subroutine that the test is found in. e.g. sub Analog_Tests - again in the testplan, is the subroutine called in the "sub Test_Sections" subroutine? e.g. call Analog_Tests (Failed_In_Analog, Mode$ & AnalogMsg$) Thanks. |
JasonXiong 发表于 2019-1-7 19:40 嗨adrianc,覆盖分析师错过了一些电阻(不是全部)。 对于那些遗漏的电阻: - 模拟目录中测试文件中的测试语句未被注释。 - 测试仪包括这些电阻,即:测试电阻“r6”测试电阻“r7”测试电阻“r8” - 电阻测试包含在Analog_Tests子程序中。 请参阅下面的“呼叫”:如果记录或不学习,则调用Analog_Tests(Failed_In_Analog,Mode $& AnalogMsg $)如果boardfailed然后subexit end if *我将向您发送一封电子邮件,其中包含一些电阻测试源文件和Analog_Tests子例程 测试计划。 谢谢,何塞 以上来自于谷歌翻译 以下为原文 Hi adrianc, Coverage Analyst has missed some resistors (not all of them). For those missed resistors: - The test statement inside the test file on the analog directory is not commented. - The testorder includes these resistors, i.e.: test resistor "r6" test resistor "r7" test resistor "r8" - Resistors tests are included in the Analog_Tests subroutine. See below the "call": if Logging or not learning then call Analog_Tests (Failed_In_Analog, Mode$ & AnalogMsg$) if boardfailed then subexit end if * I will send you an email with some resistor tests source files and the Analog_Tests subroutine from the testplan. Thanks, Jose |
1296 浏览 0 评论
2377 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1132浏览 1评论
759浏览 0评论
941浏览 0评论
1296浏览 0评论
GMT+8, 2024-12-27 08:45 , Processed in 1.547600 second(s), Total 88, Slave 72 queries .
