电子发烧友william hill官网
我们这里有一个E4411B,我们想测量典型CMOS逻辑电平ADC时钟的抖动。
当然,频谱分析仪有75欧姆的N型射频连接器。 好像我需要一个适配器,它将采用典型的示波器探头并将其与分析仪的输入配对。 这样的事情存在吗? 以上来自于谷歌翻译 以下为原文 We have an E4411B here, and we'd like to measure the jitter on typical CMOS logic-level ADC clocks. Of course the spectrum analyzer has the 75-ohm N-type RF connector. Seems like I need an adapter which will take a typical oscilloscope probe and mate it to the analyzer's input. Does such a thing exist? |
正如'tabbot'所说,频谱分析仪的输入可能是50欧姆的连接。
在一个完美的世界里,这很容易。 你没有说你有什么“典型的示波器探头”,但它可能是1Mohm探头。 将其与50欧姆输入相匹配并不容易。 如果你继续这样做,这将变成一个真正的“科学项目”。 至少,您需要一个E2697A,它可以转换1M探头,用于Agilent 50欧姆示波器输入。 然后你需要一个N1022B(需要电源),将50欧姆输入转换成3.5mm连接器。你需要为N1022B提供电源,而且我没有随时可用的部件号。 最后,您需要一个3.5毫米的N型适配器。 不用说,不支持或建议这样做。 对此没有简单的解决方案。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦william hill官网 在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 As 'tabbot' says, the input to the Spectrum analyzer is probably a 50 Ohm connection. In a perfect world, this would be easy. You don't say what "typical oscilloscope probe" you have, but it's probably a 1Mohm probe. Mating this to a 50 Ohm input isn't easy. This will turn into a real 'science project' if you go ahead with it. At minimum, you will need an E2697A, which converts a 1M Probe for use with an Agilent 50 Ohm scope input. Then you will need an N1022B (which needs power) which converts that 50 Ohm input into a 3.5mm connector.. You will need a power supply for the N1022B, and I don't have that part number readily available. You will, lastly, need a 3.5mm to Type N adapter. Needless to say this isn't supported or recommended. There isn't an easy solution for this. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
1305 浏览 0 评论
2381 浏览 1 评论
2202 浏览 1 评论
2073 浏览 5 评论
2957 浏览 3 评论
1155浏览 1评论
764浏览 0评论
963浏览 0评论
1305浏览 0评论
GMT+8, 2025-1-1 08:18 , Processed in 1.458908 second(s), Total 82, Slave 63 queries .
