电子发烧友william hill官网
嗨,
我使用System Generator 13.2和matlab / Simulink 2010b。 当我要开始一个大项目时,我试图在小型模型(解调器,过滤器等)中进行模拟,然后再实例化。 在模拟我使用System Generator生成代码之后。 生成了很多代码,我不知道我的项目需要哪些代码来实例化其他块。 然后我开始了它将只是一个块/模型。 然后我再次看到生成了太多的代码。 我是否需要项目中的所有代码才能正常运行? 或者我需要在项目中与其他块/模型结合使用多少代码? 非常感谢提前。 最好的祝福, 基兰 以上来自于谷歌翻译 以下为原文 Hi, I m using System Generator 13.2 with Matlab/Simulink 2010b. As i m going to start a big project, i was trying to simulate in small models (demodulator, filter etc) and then instantiate later. After simulating i m generating the code using System Generator. lots of code is generated and i dont know which code is necessary for my project to instantiate with other blocks. Then i started how it will be only one block/model. Then I saw again too much code is generated. Do i need all the code in my project to function properly?? or how much of that code i need in the project to combine with other blocks/models? Thanks a lot in advance. Best Regards, Kiran |
6个回答
嗨Kiran,
你在出口什么? HDL网表? 也许你应该开始出口NGC网表。 然后,您有一个预先合成的IP-Core Netlist文件,您可以在项目中进行实例化。 还应该有一些报告告诉你生成的文件以及它们有什么用处。 有一个很好的综合 Eilert 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi Kiran, What are you exporting? A HDL Netlist? Maybe you should swith to the export of a NGC Netlist. Then you have a single presynthesized IP-Core Netlist file that you can instantiate in your project. Also there should be some Report that tells you about the generated files and what they are good for. have a nice synthesis Eilert View solution in original post |
嗨Kiran,
你在出口什么? HDL网表? 也许你应该开始出口NGC网表。 然后,您有一个预先合成的IP-Core Netlist文件,您可以在项目中进行实例化。 还应该有一些报告告诉你生成的文件以及它们有什么用处。 有一个很好的综合 Eilert 以上来自于谷歌翻译 以下为原文 Hi Kiran, What are you exporting? A HDL Netlist? Maybe you should swith to the export of a NGC Netlist. Then you have a single presynthesized IP-Core Netlist file that you can instantiate in your project. Also there should be some Report that tells you about the generated files and what they are good for. have a nice synthesis Eilert |
嗨艾勒特,
感谢您的回复。 是的,我正在生成HDL网表。 我将切换到NGC网表。 干杯, 基兰 以上来自于谷歌翻译 以下为原文 Hi Eilert, Thanks for your reply. Yes i m generating HDL Netlist. I'll switch to NGC Netlist. Cheers, Kiran |
嗨,没人。
我是系统生成器和项目导航器的新手,我需要一些帮助。 我在模块苍鹭fpga14上有fpga virtex 4,我需要实现一些程序。 我想用系统生成器设计程序,因为我不熟悉vhdl并在项目导航器中导入它,其中我有virtex 4的重要数据示例(如时钟,引脚等)。 我的问题是我不知道如何在我现有的例子中连接我的转换代码来自系统生成器和vhdl代码。 谁能帮我? 以上来自于谷歌翻译 以下为原文 Hi everobody. I am new with system generator and project navigator and i need some help. I have fpga virtex 4 on module heron fpga14 and i need to implement some program. I thought to design program with system generator because i am not familiar with vhdl and import it in project navigator where i have example with important data of virtex 4 (like clock, pins etc.). My problem is that i dont know how to connect my converted code from system generator and vhdl code in my existing example. Can anyone help me? |
嗨,
您需要在Simulink中为您的模型从System Generator创建NGC网表。 然后打开项目并查看* .vhd文件。 获取此vhdl文件并复制到您的项目中并“实例化”它们以连接到现有项目。 如果您是System Generator的新手,最好从小程序开始(它可以只是AND门)并尝试了解它发生了什么。 在互联网上阅读“实例化”的含义。 然后我认为它会帮助你更好地理解。 注意:它是一个新帖子。 更好的发布下一次在一个新的线程。 谢谢。 干杯, 基兰 以上来自于谷歌翻译 以下为原文 Hi, you need to create NGC netlist from System Generator for your model in Simulink. then open the project and see that *.vhd files. Take this vhdl files and copy in your project and "instantiate" them to connect to the existing project. If you are new to System Generator better start with small programs (it can be just AND gate) and try to understand what it is happening. Read in internet what "instantiate" means. Then i think it would help you to understand better. Note: its a new post. better post next time in a new thread. thanks. Cheers, Kiran |
谢谢kchalla,我会试试。
干杯, spale 以上来自于谷歌翻译 以下为原文 Thank you kchalla , i will try. Cheers, spale |
2427 浏览 7 评论
2828 浏览 4 评论
2295 浏览 9 评论
3377 浏览 0 评论
2467 浏览 15 评论
1281浏览 1评论
592浏览 1评论
455浏览 1评论
2010浏览 0评论
736浏览 0评论
GMT+8, 2024-12-26 18:24 , Processed in 1.829972 second(s), Total 58, Slave 52 queries .
