电子发烧友william hill官网
是否可以以编程方式设置眼睛边界百分比?
我认为一种可行的方法是STOR / REC范围设置,但如果可能的话,我想直接改变百分比。 以上来自于谷歌翻译 以下为原文 Is it possible to programatically set the eye boundary percentages? I think one possible way to do this would be to STOR/REC the scope setup, but I wanted, if possible, just to change the percentages directly. |
Hello这是一个命令,它应该有助于以编程方式为86100C设置掩码边距。
+:MTESt:MMARgin:PERCent + +此命令设置要应用于所选蒙版的蒙版边距量。+ +是一个整数,-100到100,以百分比表示蒙版边距。+有关语法的更多详细信息 第242页下面。 http://cp.literature.agilent.com/litweb/pdf/86100-90086.pdf请告诉我这是否有帮助.....问候,约翰 以上来自于谷歌翻译 以下为原文 Hello Here is a command which should help set the mask margins programmatically for the 86100C. +:MTESt:MMARgin:PERCent + +This command sets the amount of mask margin to apply to the selected mask.+ + is an integer, –100 to 100, expressing the mask margin in percent.+ More details on the syntax are on page 242 below. http://cp.literature.agilent.com/litweb/pdf/86100-90086.pdf Let me know if this helps out..... Regards, John |
一巷清苑 发表于 2019-2-14 12:02 嗨约翰,谢谢你的回复。 我尝试发布:MTESt:MMARgin:PERCent并没有改变我所针对的参数。 具体来说,我对可以在用户界面上访问的Eye Boundary百分比感兴趣,如:Measure-> Setup& 信息 - >配置测量...->眼睛边界。 我现在想的是,如果不保存具有所需边界的状态并切换到那个状态,这可能是不可能的。 。 。 以上来自于谷歌翻译 以下为原文 Hi John, thanks for your response. I tried issuing :MTESt:MMARgin:PERCent and it didn't change the parameters I'm targeting. Specifically, I'm interested in the Eye Boundary percentages that can be accessed on the user interface like this: Measure->Setup & Info->Configure Meas...->Eye Boundary. I'm thinking now maybe this is impossible to do without saving a state with the desired boundaries and switching to that. . . |
1298 浏览 0 评论
2378 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1142浏览 1评论
760浏览 0评论
951浏览 0评论
1299浏览 0评论
GMT+8, 2024-12-29 09:32 , Processed in 1.181857 second(s), Total 48, Slave 42 queries .
