扫一扫,分享给好友
大家好,
我正在使用ISE 14.1。 我计划在ISIM中模拟mydesigns。 在我的设计中,我有两个用户定义的库,lib1和lib2,一些过程(例如procedure1)在lib1中定义,它们在lib2中的函数(例如function1)中调用。 当我编译时,它说“不能从纯函数function1中调用副作用procedure1”,即lib1中的函数不能被lib2中的函数调用。 我确定我已经在我的主vhdl文件中包含了所有库。 有没有人在此之前解决过这个问题? 怎么解决? 实际上这些库在modelsim中工作,我用脚本编译。 我想知道为什么xilinx报告错误,以及如何解决它。 任何身体都有线索? 任何答案将不胜感激! 谢谢你的时间! 以上来自于谷歌翻译 以下为原文 Hi all, I'm using ISE 14.1. I plan to simulate my designs in ISIM. And in my design, I have two user defined libraries, lib1 and lib2, some procedures (for example procedure1) are defined in lib1, and they are called in functions (for example function1) in lib2. When I compiled, it says "Cannot call side-effect procedure1 from within pure function function1", namely procedures in lib1 can not be called by functions in lib2. I'm sure I have already include all libraries in my main vhdl file. Has anybody encounted this problem before? How to solve it? Actually the libraries works in modelsim, where I compile with script. I'm wondering why xilinx report errors, and how to sovle it. Any body have a clue? Any answer will be appreciated!! Thanks for your time! |
这是VHDL还是Verilog?如果是VHDL,它是“纯函数”的本质,它们不允许有副作用。
'不纯的功能'可能有副作用。 ------------------------------------------“如果它不起作用 模拟,它不会在板上工作。“ 以上来自于谷歌翻译 以下为原文 Is this VHDL or Verilog? If VHDL, it is the nature of 'pure functions' that they are not permitted to have side effects. 'impure functions' may have side effects. ------------------------------------------ "If it don't work in simulation, it won't work on the board." |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1794浏览 1评论
624浏览 1评论
486浏览 1评论
2037浏览 0评论
763浏览 0评论
GMT+8, 2025-1-14 02:44 , Processed in 1.186548 second(s), Total 75, Slave 59 queries .
