我正在为一个项目工作,我在斯巴达3E入门套件中的xilinx ise设计套件13.2中完成了VHDL编码。
现在,我如何制作RTL原理图并为此实现顶层模块? 以上来自于谷歌翻译 以下为原文 I am working for a project and I have done VHDL coding in xilinx ise design suite 13.2 in spartan 3E starter kit. Now, how do I make the RTL schematic and implement the top module for this? |
6个回答
你好,
由于您使用源文件创建了一个项目,因此您需要使用按钮合成-XST& 在ISE GUI中实现Desgin,如ise snapshot attachement所示,以便合成或实现设计。 有关更多详细信息,请参阅ISE教程http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_2/ise_tutorial_ug695.pdf -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- -------------- 以上来自于谷歌翻译 以下为原文 Hello, Since you have a created a project using the source files, you need to use the pushbuttons synthesis-XST & Implement Desgin in the ISE GUI as shown in the ise snapshot attachement in order to synthesize or implement the design. Please refer to the ISE tutorial for more details http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_2/ise_tutorial_ug695.pdf --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------- |
我找不到按钮合成-XST&
在我的电脑上的ISE GUI中实现Desgin,并且该快照看起来与我不同,你的情况如何?你的电脑操作系统是什么?windows xp或windows 7? 以上来自于谷歌翻译 以下为原文 i can`t find the pushbuttons synthesis-XST & Implement Desgin in the ISE GUI on my PC,and that snapshot looks different from my,how is your situation?what is your pc os?windows xp or windows 7? |
你在使用PlanAhead吗?
XPS? ISE看起来与achutha的截图相似了一段时间了。 以上来自于谷歌翻译 以下为原文 Are you using PlanAhead? XPS? ISE has looked similar to achutha's screenshot for a while now. |
如果您使用的是ISE项目导航器,请在布局选项卡中选择默认布局,以便您可以看到我之前快照中显示的所有窗口。
-------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- -------------- 以上来自于谷歌翻译 以下为原文 If you are using ISE project navigator please select default layout in the layout tab so that you will see all the windows shown in my previous snapshot. --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------- |
在ISE GUI中实现Desgin,如ise snapshot attachement所示,以便合成或实现设计。 以上来自于谷歌翻译 以下为原文 Since you have a created a project using the source files, you need to use the pushbuttons synthesis-XST & Implement Desgin in the ISE GUI as shown in the ise snapshot attachement in order to synthesize or implement the design. |
感谢您的帮助,希望将来能获得更多帮助。
问候 Umesh制作 以上来自于谷歌翻译 以下为原文 Thanks for your help and hope to get more help in the future. Regards Umesh |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1788浏览 1评论
623浏览 1评论
485浏览 1评论
2036浏览 0评论
762浏览 0评论
GMT+8, 2025-1-13 22:30 , Processed in 1.440423 second(s), Total 54, Slave 49 queries .
