嗨........我正在做一个关于数据采集的项目...........
我已经获得了数据并以数字形式存储在内存中! 现在,我想存储时间戳以及获取的数据........! 如何执行时间戳? 我正在使用xilinx xps-edk 12.4和virtex-5板(xupv5-lx110t).................! 感谢致敬.................... 以上来自于谷歌翻译 以下为原文 hi........i am doing a project on data acquisition........... i have acquired data and stored it in memory in digital form! now,i want to store the time stamp along with acquired data........! how to perform the time stamp? i am using xilinx xps-edk 12.4 and virtex-5 board(xupv5-lx110t).................! THANKS AND REGARDS.................... |
你已经在另一个线程中问过这个问题:如何读取实时并将其存储在xps-edk中的变量中?
你需要什么分辨率? 足够1秒? 如果是这样,那么试试这个:PMOD-RTCC。 如果您需要更高的分辨率,请使用RTC获取初始时间,然后使用内部计时器递增。 或者你可以使用GPS模块。 -------------------------------------------------- -------------------------------我喜欢这些书:Free Range VHDL(免费),http://www.freerangefactory .org / site / pmwiki.php / Main / BooksVHDL for Logic Synthesis,Andrew RushtonFPGA Prototyping by VHDL examples,Pong P Chu 以上来自于谷歌翻译 以下为原文 You have already asked this question in another thread: How to read real time and store it in a variable in xps-edk? What resolution do you need? Is 1 sec enough? If so then try this: PMOD-RTCC. If you need more resolution then use the RTC to get the initial time then use an internal timer to increment. Or you can use GPS module. --------------------------------------------------------------------------------- I like these books: Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books VHDL for Logic Synthesis, Andrew Rushton FPGA Prototyping by VHDL Examples, Pong P Chu |
2453 浏览 7 评论
2848 浏览 4 评论
2312 浏览 9 评论
3392 浏览 0 评论
2489 浏览 15 评论
1855浏览 1评论
626浏览 1评论
487浏览 1评论
2038浏览 0评论
766浏览 0评论
GMT+8, 2025-1-16 21:52 , Processed in 1.270154 second(s), Total 75, Slave 59 queries .
