你好
在PMSP单/双FOC SDK v3.4版本说明中它说: ENCODER速度传感器功能:所选定时器的一个输入捕捉引脚必须接地,根据使用的重新映射和基本原理:tiM2时为IC4,TIM3为IC4,TIM4为IC3,TIM5为IC4 ; 我正在使用STM3210B-MCKIT(MB459)以及提供编码器反馈能力的Shinano电机。在此设置中,TIM2将用于MCU引脚PA0-PA3,或外设TIM2通道1-4。 根据“已知限制”,需要PA3(TIM2 Ch 4(IC4))接地。 但是我注意到,在电机开发套件(UM0426)的原理图上,TIM2 Ch4没有接地 - 相反,它用于模拟电压读数。 在我们的应用中,我们使用3x大厅的滑板,但没有编码器。请您澄清“已知限制”说明吗? 也许“已知限制”注释应指定霍尔效应传感器,但没有编码器功能?我很困惑。请澄清一下。 谢谢 卢克 #编码器释放小钞限制 以上来自于谷歌翻译 以下为原文 Hi In the PMSP single/dual FOC SDK v3.4 RELEASE NOTE it says: ENCODER speed sensor function: one Input Capture pin of the selected timer must be grounded, according to the remapping in use and this rationale: IC4 in case of TIM2, IC4 in case of TIM3, IC3 in case of TIM4, IC4 in case of TIM5; I am using STM3210B-MCKIT (MB459) along with the supplied Shinano motor which has the capability of encoder feedback. In this setup, TIM2 would be used over MCU pins PA0-PA3, or in terms of peripherals TIM2 channels 1-4. According to the 'Known Limitations' then, it is required that PA3 (TIM2 Ch 4 (IC4)) is grounded. However I note that on that on the schematic diagram for the motor development kit (UM0426) that TIM2 Ch4 is not grounded - rather, it is used for analog voltage reading. In our application we use 3x hall snesors, but no encoder. Would you kindly clarify the 'Known limitations' note, please? Perhaps the 'Known limitations' note should specify Hall Effect sensors, but without the encoder function? I am perplexed. Kindly clarify. Thanks Luke #encoder-release-note-limitation |
Ciao Luke,
限制仅适用于编码器,不会影响霍尔传感器。 此外,STM32F10B是一个普通的purpouses板,所以我们不能设置它可以重复用于其他purpouse的引脚。即使此引脚与评估板中的固定电压一起使用,编码器管理也能正常工作,因为该引脚只对该引脚的上升沿或下降沿有效。但我建议尽可能避免它。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Luke, The limitation is only for Encoder and not affect the Hall sensors. Moreover the STM32F10B is a general purpouses board and so we can't setup it groundig a pin that can be reused for other purpouses. The Encoder managemet works even if this pin is used with a fixed voltage like in the evaluation board because the algorthm is sensible just to a rising or falling edge on that pin. But I suggest to avoid it if possible. Ciao Gigi |
2762 浏览 1 评论
3248 浏览 1 评论
1820 浏览 1 评论
3663 浏览 6 评论
6055 浏览 21 评论
1346浏览 4评论
209浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
364浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
458浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
281浏览 2评论
GMT+8, 2025-1-4 11:49 , Processed in 1.131172 second(s), Total 76, Slave 60 queries .
