要补充jkinzie更改显示格式的答案,请转到视图>属性。然后,您将看到属性面板,要以不同格式显示的属性是NumberFormat,双击它并修改为
你想要使用的格式.Vee没有注意数字的格式,它只是在显示时你必须指定你想如何看它。编辑:你可以尝试做一个像#B1010101010101010这样的常量(
#B表示它是二进制的并且用一个简单的字母数字对象显示它,但是将其NumberFormat属性改为Dec.Vee会自动将#B .....改为常量对象中的十进制,以防你想继续看
它在二进制上显示更改Constant对象的NumberFormat。注意:您可以将#B或#b用于二进制,#H或#h用于十六进制。
以上来自于谷歌翻译
以下为原文
To complement jkinzie´s answer to change the display format, go to View > Properties.
You will then see the properties panel, the property you want to move in order to display in different formats is the NumberFormat, double click on it and modify to the format you want to use.
Vee doesn´t pay attention to the format of the number, it is just when displaying when you have to specify how do you want to see it.
Edit:
You can try doing a constant like #B1010101010101010 (#B means it is binary) and displaying it with a simple alpha numeric object but changing its NumberFormat property to Dec.
Vee will automatically change the #B..... to decimal in the constant object, in case you want to keep seeing it displayed on binary change the NumberFormat of the Constant object.
Note:
You can use #B or #b for binary, #H or #h for hex.
以上来自于谷歌翻译
以下为原文
Edit:
Note:
