嗨,我有一个电源6675A,当电源接通时,输出跳闸到OT(过温)。
已经检查了RT300(热敏电阻),R530(10k)和U513(比较器)组件,但没有一个损坏。 我需要帮助。 请有人告诉我哪一部分会使OT绊倒? 谢谢Atiq 以上来自于谷歌翻译 以下为原文 Hi I have a power supply 6675A which output is tripped to OT (Over Temperature) when power on . Already check the RT300 (Thermistor), R530 (10k) and U513 (comparator) components but none of them is damaged. I need help. Please someone tell me which part will make the OT tripped? Thanks Atiq |
5个回答
在http://cp.literature.agilent.com/litweb/pdf/5961-2583.pdf手册中,建议检查热敏电阻A5RT770或比较器A5U513
以上来自于谷歌翻译 以下为原文 In the manual http://cp.literature.agilent.com/litweb/pdf/5961-2583.pdf it is suggested to check the Thermistor A5RT770 or comparator A5U513 |
嗨,你能解决OT问题吗?
也可能是其他地方导致OT事件的失败。 请告诉我们。 以上来自于谷歌翻译 以下为原文 Hi, Were you able to resolve the OT issue? It could also have been that there was a failure somewhere else causing the OT event. Please let us know. |
嗨Yup在服务手册中检查热敏电阻和比较器我做了那个但发现热敏电阻仅用于风扇速度控制而不是用于OT跳闸。 不,我仍然无法修复它。 希望你们能帮助我。 非常感谢。 关心Atiq 以上来自于谷歌翻译 以下为原文 Hi Yup in the service manual to check the thermistor and comparator and i did that but found that the thermister just for fan speed control not for OT trip. No, i still not able to fix it. Hope you guys can help me. Thank you so much. Regards Atiq |
嗨,我有一个问题。
微控制器80C51需要在何时使用新的微控制器? 我在哪里可以找到hex文件? 或者我可以从原来的微控制器读回来吗? 请帮助问候Atiq 以上来自于谷歌翻译 以下为原文 Hi I have a question. A microcontroller 80C51 need to be programmed right when to use new one? Where can i find the hex file? or can i read it back from its original microcontroller? Please help Regards Atiq |
U504(80C51)是安捷伦编程的部件。 该IC的代码是安捷伦的知识产权,不向公众开放。 PeterW 以上来自于谷歌翻译 以下为原文 U504 (80C51) is an Agilent programmed part. The code for this IC is the intellectual property of Agilent and is not available to the public. PeterW |
1342 浏览 0 评论
2401 浏览 1 评论
2232 浏览 1 评论
2088 浏览 5 评论
2980 浏览 3 评论
1294浏览 1评论
792浏览 0评论
1084浏览 0评论
1342浏览 0评论
GMT+8, 2025-1-28 04:13 , Processed in 1.193088 second(s), Total 83, Slave 67 queries .
