电子发烧友william hill官网
嗨,大家好,
我有一个使用RAMB16_S36原语作为指令RAM的项目 我想初始化它的前几位,就像给BRAM提供coe文件一样。 如何手动将初始值写入RAMB16_S36? 我发现有一堆参数[255:0] INIT_00 = 256'h00000000000000000000000000000000000000000000000000000000000000000000; 在模拟库中。 但我不知道INIT_00是否意味着RAMB16_S36的前256位,我不确定这种变化是否适用于综合。 谢谢! 以上来自于谷歌翻译 以下为原文 Hi guys, I have a project using RAMB16_S36 primitive as instruction RAM I want to initialize the first several bits of it, as like giving coe file to BRAM. How to manually write initial values to RAMB16_S36 ? I found there are a bunch of parameter [255:0] INIT_00 = 256'h0000000000000000000000000000000000000000000000000000000000000000; in simulation library. But I don't know if INIT_00 means the first 256 bits of RAMB16_S36 , and I am not sure if this change applies to synthesis. Thanks! |
3个回答
本文档http://www.xilinx.com/cn/xp/xilinx10/books/docs/spartan3_hdl/spartan3_hdl.pdf告诉您如何使用init参数。
它们在合成过程中使用。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 this document http://www.xilinx.com/itp/xilinx10/books/docs/spartan3_hdl/spartan3_hdl.pdf tells you how to use the init parameters. They are used during synthesis. - Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented.View solution in original post |
它们在合成过程中使用。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 this document http://www.xilinx.com/itp/xilinx10/books/docs/spartan3_hdl/spartan3_hdl.pdf tells you how to use the init parameters. They are used during synthesis. - Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
2429 浏览 7 评论
2831 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1389浏览 1评论
597浏览 1评论
462浏览 1评论
2015浏览 0评论
739浏览 0评论
GMT+8, 2024-12-29 19:13 , Processed in 1.293202 second(s), Total 80, Slave 64 queries .
